Reduced Ring Gap, Blower Specific Pistons, E85
Old May 11, 2022 | 09:09 AM
FormulaBoat's Avatar
Default Reduced Ring Gap, Blower Specific Pistons, E85
Dedicated E85 LSA (6.2L) build. Wiesco blower pistons, 11:1 compression, 15psi pulley ratio (approx), 224/232 cam (114.5CL, 0.590" x2). The ring package is located much lower than conventional on the Summit (Wiesco) Pro LS pistons. Included instructions say to gap @ 0.024". Anybody else running this gap, and are you seeing any blow-by doing so? Any possibility to reduce the gap due to the ring package lower geography, or the use of E85 fuel? Probably not worth butting a ring, but at least wanted to ask.
Thanks.
Old May 11, 2022 | 03:21 PM
Summitracing's Avatar
LS1Tech Sponsor
Do you have their part number? Usually .300 is our standard and it's not likely that Wiseco went lower than that.
__________________
800-230-3030
www.SummitRacing.com
