Dart Big M and Big M Pro max Boost
Hi everyone, I was wondering if anyone had information about the maximum sustainable pressure from the Dart Big M and Big M pro blocks. I have seen that the thickness between the cylinders is much smaller than a Dart Next2 and an LSX, I guess they can withstand much less pressure, even if knowing the Dart build quality it wouldn't surprise me if they had created such a large block that supports without problems 40 -45 psi
The following users liked this post:
Animale (05-11-2022)
thank you very much, please could you tell me at what boost pressure your friend's engine works? I'm trying to get an idea of the limits of the block, in case in my area, I can't find someone who knows how to do a proper cnc port to the dart heads. Thank you very much for your reply
It makes 2000 rwhp and probably 2200 fwhp at 40 psi. Not sure where you are looking but there are quite a few people who will do turbo BBC's. Steve Morris, Proline, Fast Times Motorsports, Harrell Engine & Dyno (HED), Thompson Motorsports, Texas Speed, TKM, CNC Motorsports etc etc. You can also purchase a number of BBC heads (Dart, AFR, Brodix) already CNC'd. I wouldn't mess with buying castings then having someone CNC them. Unless you're trying to get crazy you don't need an exotic head on a BBC with boost to make big power.
https://www.airflowresearch.com/cyli...cylinder-head/
https://www.cnc-motorsports.com/perf...588-short-deck
