Terminator 3 bar map?
Old May 7, 2022 | 10:01 AM
4EyedTurd1's Avatar
Default Terminator 3 bar map?
Is the Holley 3 bar map the go to for boosted situations? A quick search shows the efi source ones but those seem questionable.
Old May 7, 2022 | 12:12 PM
theunderlord's Avatar
GM 3 bar Map # 12592525 will get you where you want to go.
Old May 9, 2022 | 06:21 PM
customblackbird's Avatar
that’s really a 2.5 bar sensor. If your going to want a true 3 bar to get a full 3 bar then look elsewhere.
Old May 10, 2022 | 01:53 PM
RonSSNova's Avatar
We noted recently that the LS9 sensor stops at approx 284kpa. P01 ECU, 3 bar tune.
My buddy was running 25 psi, along with the scramble button couple weeks ago at LS Fest In Vegas. I am the tuner, but not there. He was sending me logs. Turned out he was looking at the kpa in the data logs and not seeing it move so he upped the scramble dome pressure.
Boost hit 32 psi. Oops. Truck was bad *** fast though!
I never knew this was an issue with this sensor. No wonder Holley calls it a 2.5 bar map.
Old May 10, 2022 | 02:14 PM
****, I remember that now. My bad.
LowDollarMotorsports has 1,2,3,4,5 and 6 Bar Map sensors for decent prices.
Old May 10, 2022 | 03:47 PM
RonSSNova's Avatar
Good find. Thanks.
The trick will be calculating the slope and offset for the GM ecu. Easy as pie for the Terminator
Old May 10, 2022 | 05:26 PM
Good find. Thanks.
No prob! Of note too, LDM specifically say "not for HPTuners"
Old May 10, 2022 | 05:58 PM
RonSSNova's Avatar
I made my own 3 bar map sensor by replacing the guts in a factory 1 bar sensor. Used a Freescale Map sensor IC. If you get the correct data, you can calculate offset and linear. I just need to remember how. If they give enough data with their sensor.
Could also be calibrated manually. But that’s real clunky.
I didn’t see where it said not for HPTuners?
Old May 11, 2022 | 08:07 AM
4EyedTurd1's Avatar
I went ahead and grabbed the GM one and pigtail from current performance
Old May 11, 2022 | 11:59 AM
Scroll to the bottom of this link, it's the last sentence
"Not compatible with FAST XFI or HP tuners."
Old May 11, 2022 | 01:39 PM
RonSSNova's Avatar
That will work well for you.
Sorry we hijacked your thread.
Old May 11, 2022 | 01:42 PM
RonSSNova's Avatar
Thats a 6 bar! I was looking at the 4 bar. 😊
Old May 11, 2022 | 09:23 PM
LSswap's Avatar
I've been using this type of GM 3 bar map sensor for over 20 years, They work!
Original GM 3 Bar
In addition, I like to get the map sensor a little bit away from the manifold to smooth manifold pulses and get a more accurate reading. The longer the vaccuum/boost line, the more smoothing.
Old May 11, 2022 | 11:36 PM
I mean, if you're not partying at the 6 bar level, are you really partying at all?
Old May 12, 2022 | 12:50 AM
RonSSNova's Avatar
An oldie but goodie. Would be interesting to measure one.
Old May 12, 2022 | 12:54 AM
RonSSNova's Avatar
Ha! Had an 8.5 outlaw guy with an LS say "if you aren't running 45 psi you're a girl"!
I told him I'd bring my pull on tutu to the next race. :-)
Old May 12, 2022 | 03:00 AM
jayyyw's Avatar
Used the Low Doller 5 bar on my last car with the Terminator X. No issues. He sends you the data, an extra plug, and pins with each sensor.
Old May 12, 2022 | 08:03 AM
LSswap's Avatar
you don't want a map sensor that is way higher than your target boost. You will lose resolution that way.
