NERD ALERT! Mileage tuning
Old Jun 5, 2022 | 12:16 PM
3 window's Avatar
Default NERD ALERT! Mileage tuning
So a week or so ago I had a buddy drive me around in the Nova while I tapped the keys on the laptop. On E85 with a 25-30 mph wind, we were able to get 16.5 mpg out of it at about 60 mph. Yesterday I threw a few gallons of pump 93 in it which gave me a blend of E45. Mileage went up to 20 mpg at 50 mph (and 19 at 40 mph). This is at 3400 lbs, a glide with a 17-0 converter, 3.55 gear and a 275 tire. I’m sure with straight pump 93 I could make it to about 24 mpg seeing it’d be about 14-15% less fuel than the E45 blend.
Note: I never touched the timing while tuning during cruise, only my target AFR. I’d bet there’s a mile or so in the timing as well.
Old Jun 5, 2022 | 01:07 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
That's cool, what did it want? Get leaned out?
Old Jun 5, 2022 | 01:52 PM
3 window's Avatar
Yeah, just leaned it out and watched fuel usage. Ended up 15-15.2 AFR above 45 mph or so.
Old Jun 5, 2022 | 05:50 PM
LilJayV10's Avatar
I'm not sure why it's such a surprise that you get better mileage with less ethanol content.
Old Jun 5, 2022 | 05:59 PM
3 window's Avatar
It’s not a surprise, just a statement about results.
Old Jun 5, 2022 | 09:05 PM
LS1Tech Co-Founder
One of these days I'd like to check out your Nova.
Old Jun 8, 2022 | 07:36 PM
jester1's Avatar
Ha no way! Get all you can get before you get greeted with this vision one day.
Old Jun 9, 2022 | 06:54 AM
GMCGreg's Avatar
That's $ 9.18 / gal. They're really killing us up here - mileage matters !!!
Old Jun 9, 2022 | 11:20 AM
Ls7colorado's Avatar
So would advancing timing or retarding timing be better for economy? Ive heard both ways, seems in my mind advancing would help....
Old Jun 9, 2022 | 02:53 PM
TrendSetter's Avatar
leaner mixtures burn slower so you advance the timing.
Old Jun 9, 2022 | 03:04 PM
Kawboom's Avatar
I am pretty sure that this is simply untrue.
Old Jun 15, 2022 | 03:36 PM
so youre saying leaner burns faster in which case you retard the timing?
Old Jun 17, 2022 | 12:54 PM
Black_Sunshine_99's Avatar
Old Jun 18, 2022 | 12:38 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Being pretty sure does not make you correct in this case. The fastest fuel burn is typically achieved slightly richer than stoich. If you go leaner you definitely get a slower flame front. Lean burn also usually results in quite the annoying decrease in power, but the OP is looking at economy, so that is a whole different conversation.
Old Jun 18, 2022 | 03:52 PM
LS1Tech Co-Founder
From what I've seen with single turbo LS builds, there is a range of timing they like for cruising and I'm sure Jamie (3 window) keeps it somewhere in there.
Jay Blanchard (a great wiring guy and fuel system and fabrication guy in Grand Haven MI) crews for a Nova like that that just won Summit Drag Week 8.50 index, they get about 10mpg on E85.
