Bosch 210's
The guy answering the phone @ VS was polite enough to spend time confirming the height and what not for my LSA application. He explained the difference of it being the proper fit for LSA fuel rails, but need a thicker lower O ring. Forgot the exact dimension, he mentioned it, and it was available from both aftermarket and GM. I think the LSA lower O ring from GM was 0.5mm larger OD? Probably since it is pressurized, vs a vacuum only LS3 manifold.
Its because most cheap injectors dont flow with in 1-2%. Your set might flow within 1-2% but there are hundreds of others that wont. As a shop its not worth the time to fight trying to tune a cheap injector that may not be able to ever idle clean or work in their setup vs having an injector that you know will work. Im not knocking the 210's, we tune those if they are flow matched or have been tested but not if they are knock offs. We saw so many injector issues with de-capped, cheap knock off's and injectors that sit with old fuel in them we bought the top of line injector machine. We never try to sell anyone injectors, we give them a list of what we feel are good injectors, if they want to buy them from us thats fine but it doesnt matter to us.
After flowing, testing and cleaning injectors for almost 2 years now it really changed my perspective on injectors. We have also a good number of tests on the dyno changing just injectors with surprising results. When you get to the big injectors 1650cc or bigger there is huge differences between brands.
