Drain lines
Old Jun 15, 2022 | 03:44 PM
skippydn's Avatar
Default Drain lines
Anybody have any pics of how they ran their oil drain lines on the 98-02 Huron speed twin turbo kit. And yes iv used the search feature and didn't find anything.
Old Jun 15, 2022 | 04:22 PM
theunderlord's Avatar
The native search feature can be tough, try adding "LS1tech" to the end of a google search. "Huron Turbo Drains LS1Tech"
Old Jun 17, 2022 | 12:22 PM
Black_Sunshine_99's Avatar
No pics but I used -10 AN line w/ a 90 off the turbo ran to the oil pan and tapped into the pan 1" below the pan rail above the drain.
Never had any issues with oil backing up unless I was breaking on a down grade like a highway off ramp at speed, even then only very little smoke.
I'd suggest 1/2" or 5/8" hardline if you can swing it, straight to the front of the pan or timing cover, you of course want some slope to it so oil doesn't back up.
It's pretty straight forward, good crank case evacuation is key as well, a good PCV catch can system is highly recommended, the Mighty Mouse PCV can worked well for me.
Old Jun 23, 2022 | 10:34 AM
427Trans am's Avatar
Which twin turbo Huron kit you asking about ?
