Turbo 5.3 Microsquirt Idle Issues
The setup: Bone stock LM7 with Pac 1218's and Siemens Deka 80's, GT45 turbo, GM 3 bar map, Bosch 044, running on Microsquirt, typical low-buck deal.
I cannot for the life of me get this thing to idle leaner. Hangs out around 10.5-11.0 AFR, rich smelling exhaust, smoky, idles poorly, doesn't really like certain throttle inputs, overall just acts strange. I've played around with the VE table, ignition table, injector dead time, required fuel value, and tried just about every idea I can find online without really making much of a difference. Injector pulse width likes to hang around 1.2 to 1.3 ms and idle, which is around the dead time for Deka 80's, and no amount of adjustment seems to change that. Base fuel pressure is set at 43.5 psi. At this point, I'm pretty well out of ideas, and I'm all ears to any suggestions/guidance that's out there. I'll attach the tune file as well as a datalog of the truck running on that tune. Any help is greatly appreciated, Thanks!
ETA: don't tune with required fuel calcs, or dead time calcs. Enter the correct information and leave it alone.
I bought a used set of Deka 80's years ago the previous owner said were like new.
Turns out he ran E85 in them and never pickled them before removal so several of them were gummed up.
As a result I could never get my AFR's above 11.7 because some of the injectors were just dumping fuel.
