Really dumb question on crank pinning for running a blower.
The keyway for the balancer appears to use common old school chevy 3/16x 3/4 long woodruff key.
I am running an Innovators West balancer and hub that is cut for 3/16s keys.
Would this woodruff key be strong enough for spinning a crank driven blower?
If anyone is wondering it's for a custom LSA supercharger application that is driven off of an 8 rib belt from the main accessory belt and not a dedicated blower drive belt if that even matters.
I also have a standard horizontal crank pinning kit as well that uses the 3/4 inch long pieces of drill rod that you jam into a hole you drill from the front.
I am a big believer in keeping **** simple and I'd rather not swiss cheese this crank snout if I don't need to.
A quick google search has showed me that I'm not the first one to do this and I probably won't be the last.
Sucks though as it will be a major setback for my fictitious deadline.
So you have to aim this thing and hope for the best on getting it aligned. Even though I measured twice I think it was a little fat and had to have been a little tall.
At this point I am hoping that IW sells a hub with no keyway and just let me drill and pin it old new school.
Andrew
Is that balancer hub aluminum?
Andrew
I only had the whole thing in the oven at 240 and only for a half hour. Maybe a little impatient.
I'll see what IW recommends on Monday. I'm just hoping they don't make me send it in as that could take forever. I don't want to get in a situation where it's faster to buy a new balancer.
The hub is steel but it is remarkably thin where they cut the keyway slot in it (maybe .125") and their slot is full length which IMO makes it even weaker. Especially being a square keyway.
Andrew
Long story longer, I did end up buying another balancer which Summit somehow got to me overnight even though I selected free shipping. I love @Summitracing Shipped off my damaged unit to IW slow boat for repairs and inspection. It will be sold off once returned unless they say it's going to cost 500 bucks to fix it lol. At that point they can keep it.
IW did say that using the small block chevy woodruff key would be totally fine for my application and power level to key the balancer onto the crank for supercharger drive.
I took my time and carefully file fit the woodruff key so that I know for a fact it has proper fit and clearance. I heated the balancer up at 270F for an hour and I even iced the crank snout for a half hour. Son of a bitch still wasn't even close to thinking about sliding on. Kinda makes me wonder if the eagle forged crank snout may be on the large side. It fought me the whole way on. It never made any scary noises or pops nor did it do the really really hard and then really really easy like last time. Very nerve racking! but it's on there.
Happy to hear we were able to get you a balancer the next day with our over $99 free ground shipping
It's on now and torqued. I'm comfortable with the installation this time and that the key is properly installed.
Also to avoid any confusion I may have created the new replacement balancer / damper is another IW part number 843 I got from Summit.
Got it back and it's good as new. Took not quite 3 weeks total.
