Interesting suggestion from NGK
NGK "Your compression and boost put you in an 8 heat range, TR8IX (3691) is for street use, if it is track use only, please use R5724-8 (7317)
and adjust it to .032”."
Just found this interesting
Folks say there is no business for a projected tip plug in a boosted engine.
The factories must not have gotten that memo, everything from the Hellcats, Demons, supercharged Corvettes, even the Lambo’s run projected tip plugs. The Hellcats projection is huge. Anyway….
However, in my own turbo car I run the R5724-8 (7317)
it’s non resisted. Seems fine. Car loves them. I do tend to get erroneous data in my logs, possible RFI interference? Car runs flawless. I run 24 psi, still basically flat tire boost. 😀
I don’t know much about the iridium Ti8x other than they are real expensive.
I think you will get a cleaner idle with the two they recommended. Other than the iridium, cheap to experiment. Although the days of $1.99 plugs are long gone sadly
I personally will not be running the iridium. I have used iridium plugs in 2 of my other cars and was never happy with them.
I won't do the iridium deals either, too expensive and I've had a few friends use them and not be happy with them.
Thought I read somewhere the TR6's were good for moderate boost and street use and the BR7ef's for higher boost but may have slight drivability symptoms on the street, I haven't noticed anything as of yet.
Are both the plugs the OP mentioned iridium style plugs?
