1964 Dodge A100 project. 5.3 with Turbo. Need advice on Cam and turbo size
LS1Tech Sponsor
Received 1,123 Likes
OP,
Cool project you have here. You've received some great advice from the community.
We wouldn't hesitate to put our SUM-8715R1 "Ghost" cam or stage 2 turbo cam SUM-8706R1 in this combo. Either would work well with your planned gears and converter. The Ghost cam would have a smooth idle to noticeable lope whereas the 8706R1 would have a steady lope. The Ghost cam has -2* of overlap and the 8706R1 has 2* of overlap so both will be easy to tune and get along with. You can pair either with our .600" lift beehives and your stock retainers and they'll be happy out to 7,000+.
We know our customers like combos so we have Pro LS cam combos to help with a cam swap. You can get a cam and spring combo or a cam, spring, and install/gasket kit combo.
- For all 8715R1 combos check here
- For all 8706R1 combos check here
Let us know if we can be of any further assistance. We'll be happy to help!
The following users liked this post:
onanysunday (10-28-2022)
OP,
OP,
SUM-8706-1DS and SUM-8706-1DT
onanysunday (10-29-2022)
Also I have looked through the specs and fail to see the difference in each of the kits:
"T" = titanium retainers, about $90 more
For street, steel is more durable. Titanium can fret and chip, being more brittle.
LS1Tech Sponsor
With duals, other than the increase in cost it's pretty much pro's. Although, we do typically recommend a trunnion upgrade kit when going with duals due to the added open spring pressure.
When looking at kits or combos check the kit/combo contents tab within the overview for the given combo. That will show you the individual parts within the kit.
- SUM-8706-1DS kit/combo contents
- SUM-8706-1DT kit/combo contents
onanysunday (11-03-2022)
