Turbo help for 5.3 vortex
Old Nov 6, 2022 | 10:00 PM
BlackMarker's Avatar
Default Turbo help for 5.3 vortex
What’s the best twin turbo setup and supporting mods to have a reliable 500whp in my bone stock 5.3
Old Nov 6, 2022 | 10:04 PM
This should be in the Forced Induction forum.
BTW, it's VORTEC not vortex
Old Nov 7, 2022 | 07:10 AM
Utinator's Avatar
Any twin turbo set-up can give you 500 whp with no mods. Even the smallest turbo kits start around 600hp at the crank. That will give you 500hp at the wheel. Huron Speed and On3 are the more popular turbo kits. Either one would work.
Before you try to run that much boost, you really should take the engine apart and open up the ring gap. A small turbo cam or truck cam will help too. The cam will make it easier to reach that hp with less boost.
Old Nov 9, 2022 | 12:22 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You can get there with a single.
Other than the things you need like WG, BOV, oil feed/return, plumbing boost control/reference, I think you should add in a Melling oil pump.
Old Nov 9, 2022 | 01:22 PM
ddnspider's Avatar
A single 7665.
Old Nov 9, 2022 | 01:44 PM
mk3cn4's Avatar
Bone stock L33 with valvesprings/injectors and single Ebay 7875/Huron Kit at 12psi and I believe I'm over 500 since I trapped at 123mph in full weight car with AC. Stock 4l60e stock diff still. Just the single turbo, supporting parts and tuning, basically effortless and probably super reliable. Time will tell.
