Turbo Headers
I made my own plug wires with a Taylor kit.
This is in a C5 and plug access kinda sucks….
Check out the KSR channel
Swapped truck manifolds to tubular headers, theres a few videos of it but cant remember if there was a turbo change in the mist and a valve spring problem mixed in. Good viewing non the less.
If you're doing a custom application and can't weld your own I'd really recommend them as you just need a miter or radial arm saw and you cut up pieces of PVC and they make it based on your mock up kit. They include small metal pieces that angle and swivel too and several small PVC pieces of different angles (I think 15, 30, 45, 60, 75 and 90 IIRC)
I probably made mine a little too long but I and my welder think they can just have a short turned in pipe to hang the turbos off of.
