Intercooler
Old Dec 9, 2022 | 12:45 PM
TrendSetter's Avatar
i had a w/a setup on my pickup truck and it worked well but it added a lot of weight. it was all up front, no rear cooler or anything, i used a second radiator in front of the stock one as the combined tank and heat exchanger. decent pump, 1" lines, overall it was well done for what it was. i towed, ripped stumps out, drove it everywhere and never had any thermal issues.
a/a is lighter, simpler, cheaper, but the w/a worked fine. 'better' is subjective.
Old Dec 19, 2022 | 11:05 AM
SteveJewels's Avatar
Veteran: Navy
There's an option here not mentioned that most guys do with an A2W at the track and that is adding ice and dumping the water after each run.
I agree and could see the water temp rising after each run, but I think this is also dependent on boost level and compressor discharge temp.
For me I'm using a fairly large turbo and not pushing it very hard, so my IAT's actually cool down when making a hit on the street which I assume is due to the added airflow through my intercooler.
All the guys I know who run A2W at the strip add ice before making a pass, drain the tank most of the way back in the pits, refill, then add ice before heading to the lanes.
I'd assume this method gets you the most benefit out of an A2W system but of course requires more planning, bring lots of ice in a chest for example.
There is another option too, mechanical refrigeration. It uses the gas side of your AC to chill the water. You can plumb it to have the charge air cooling system running but not the AC for your car so you don't have drips from the AC system at the track.
Interchillers
Killer Chiller
I did the math on this about 5 years ago. It works. The HP gain from colder IAT's far exceeds the HP consumed to run the AC system.
Old Dec 19, 2022 | 11:11 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I've got a buddy looking into the Tick a/w brick for the TSP intake manifold, any of you guys using that?
Old Dec 20, 2022 | 09:00 PM
Veteran: Navy
If only it would fit under my hood.
I'd really like to see some data on how much it cools.
Old Dec 21, 2022 | 07:32 AM
Novapat67's Avatar
Interchillers
Killer Chiller
That is really cool. This is definitely something I'm looking into for a future build. The hp cost piece is interesting, but doesn't the compressor turn off after a certain % of throttle position? If that is the case, it wouldn't really cost you anything on your run.
What have you seen people using for ac solenoids?
Old Dec 21, 2022 | 11:06 AM
Black_Sunshine_99's Avatar
@randeez did an AC cooler type setup in his Denali, seemed like it worked amazing, water temps down around 34 degrees.
Old Dec 21, 2022 | 02:28 PM
randeez's Avatar
I saw that thread and was going to comment on it - maybe its just me, but i cringe when i see an a2w right in line with the tire. If you don't ice it (read create a lot of condensation) then probably not a problem. But my a2w sheds a shitton of condensation with the chiller on. On the flip side the sandwich a2w (what I have) any condensation is over the engine or in the middle of car if it drips anything, but it does soak up a lot of heat from being over the valley.
I had to use antifreeze, otherwise it would start making slushies. It super chills the brick, close to the fluid temp i imagine, you don't really notice the iat drop as far during low flow across it. I see about 20° delta between fluid temp(30) and iat(50s). Ambient temps are 90°+ for 10 months out of the year down here
Old Dec 21, 2022 | 03:10 PM
LS1Tech Co-Founder
I hear you, I would have some condensation concerns too but let's just assume he can coat it it or have some other sort of safety solution that works.
Then what is your answer?
 Michael S. Palmer
Old Dec 21, 2022 | 08:20 PM
randeez's Avatar
id say the box is probably a better set up - more efficient, no added heat from engine, couple hundred bux cheaper for similar rated, slim chance of trashed turbo causing a core leak isnt directly into the engine, hood clearance- not sure how tall the TSP is but adding the IC to it prob wont clear most stock hoods. i doubt anyones going to argue that the intake mounted is flat out better- possibly the frankenstein iceman @ $8500, but yea ive got a few other things that money could go towards
pros of the intake mounted - less charge pipe, easier fab/packaging, the shearer fab moves the throttle body about 4" back
i have the 1800hp rated shearer fab, 13ish gallons of coolant (10 gal tank, a lot of 16an hose, intercooler) , bmw/peirburg 400 pump...overkill for most people but i had the room and weight isnt a concern.
the base of the TSP is larger than the holley iirc, so should have more surface area.
Old Dec 21, 2022 | 09:45 PM
LS1Tech Co-Founder
Yeah the brick setup (intake) would push him into a different hood.
Old May 20, 2026 | 03:45 AM
dowesoc's Avatar
Yes, as you said, depending on the demand for cooling.
Water has much more capacity to carry heat and, if the A2W core is good and well done, will pull more heat out of the charge air just like a 6.0 Powerstroke intercooler does. The other end, getting the heat out of the water, is the consideration. Drag or roll racing where the heat occurs only for a short time, you can get the heat out of the water. If you are running the FI system longer, the water temp rises and it takes longer to get the water temp down. Until you do it does not cool the charge air as much.
And yes, people have DIY'd a A2W system. You can buy the individual parts, heat exchanger, radiator, pump, tank and so on. The tricky part is the water and charge air plumbing.
You're right, a WTA performs better in traffic and at stoplights since it doesn't need airflow to cool. Your bilge pump and separate heat exchanger setup is a common DIY approach, just make sure you size the heat exchanger big enough because that's where most people go wrong on their first build.
Old May 20, 2026 | 01:25 PM
  #32
LS1Tech Co-Founder
A2W works well, that's why it's used so much for OEM applications.
