Procharger PCV setup
Old Dec 24, 2022 | 11:18 AM
Tyler Dietzenbach's Avatar
Any thoughts on this setup? No pcv or check valve, straight ventilation.
Old Dec 24, 2022 | 11:41 AM
01CamaroSSTx's Avatar
Anyone that says you cannot ventilate to atmosphere while being boosted should contact NRE and ask him what he does. Just be sure you have large enough lines to properly ventilate the crankcase. Having a 3/8" or 6AN lines off the valve covers may not be enough and you might get away with 8AN but 10AN or 12AN would be better IMO. Below is a link that may shed some more light on the subject.
https://www.superchargerforums.com/t...re-blown.2472/
Old Dec 24, 2022 | 12:59 PM
Thanks man! Yes, I'll be running 10AN lines. I have read several people say it's a bad idea.. something about vacuum or.. I honestly don't remember. I almost feel as though mightymouse mentioned it in the past too.
Thanks for link as well.
Old Dec 24, 2022 | 07:56 PM
n2xlr8n66's Avatar
It really is a wash, PCV fans like to claim cleaner oil and engine internally but really in most cases these cars aren't used hard or with a lot of miles so it really isn't ann issue.
I change the oil in mine every summer and sometimes twice if I'm beating on it but even then, we're talking less than 1,000 miles in total.
Frequent oil changes can have the same effect and when you use something like Delo 15-40 it doesn't break the bank either.
Respectfully (you guys have forgot more about LSes than I know).....but I subscribe to the vacuum / pcv / whatever means necessary to prevent pressuring the crankcase, and in ideal examples, assist in the all-important pressure differential *above and below the ring pack. Saying that, I'll likely have to re-do my setup when it doesn't work, lol.
Someone thought enough of the idea years ago that about every modern aftermarket piston today uses a single groove between the top and second ring to help alleviate the pressure build up (aka "flutter") the affects ring seal and combustion. Vacuum pump or PCV, they make power and improve combustion quality.
My 0.002 : )
Last edited by n2xlr8n66; Dec 30, 2022 at 03:13 AM. Reason: said *cylinder wall, clarified
Old Dec 26, 2022 | 01:32 PM
MIGHTYMOUSE's Avatar
when the car was stock it had a pcv system, for emissions requirements as well as performance
if you remove pcv then the oil will become dirty more quickly (pcv is a filtration process of keeping airborne contaminants from settling in the oil)
and as well with no plumbing of the crankcase fumes to be consumed then they will be emitted, which can be something people prefer not to smell, regardless of emissions
so what I came up with was the first hybrid (PCV can) that could increase the flow of the pcv system for beyond stock applications, without removing the pcv function I preferred myself, and removing oil that is consumed through the pcv
there are lots of other ways to do it, we also reinvented the breather tank a year or so ago for those who do not want / need PCV with a wet cyclonic full time vent tank called RACE
I put an XL size one of these on my personal c7z this past year since it only moves maybe 10 miles a year now (runs only methanol) going beyond 1500hp on the original engine.
it is very common to spend more in several directions / stages "saving money" before getting to us
our goal is a one stop shop to provide the final, guaranteed solution
separate from that, when the throttle body is pressurized, then the clean air source for the pcv system must be moved to pre-boost, or to an alternate, preferably filtered air source
without regulated intake manifold vacuum application to the crankcase, and without clean air being flushed through the crankcase, to constantly replace the foul air being drawn out, you do not have a pcv system
Old Jan 2, 2023 | 10:11 AM
Black_Sunshine_99's Avatar
I ran one of your PCV cans for years on my 700whp combo, at your direction I modified the vent side of the can with a -12AN line and it worked flawlessly.
The only thing it ever collected was the white gunky build up that would have been left in my valve covers lol.
