Opinions On Heat Shielding
Old Dec 18, 2022 | 08:50 AM
275Camaro's Avatar
Default Opinions On Heat Shielding
What does everyone think about heat shielding on manifolds or headers. Will it change under hood temps very much? Any significant HP gains? Is it worth spending a few hundred for coatings or shields?
Old Dec 18, 2022 | 12:25 PM
ddnspider's Avatar
Not needed for stock manifolds. Tubular I'd a different story. Plenty wrap them. Otherwise turbo blanket and wrap the hot side and call it a day.
Old Dec 19, 2022 | 10:48 AM
Black_Sunshine_99's Avatar
x2
Wrap the pipes, leave the cast pieces bare or paint them, turbo blanket is a must.
You will be amazed how much of a difference it will make in cutting down heat soak under the hood.
Old Dec 19, 2022 | 11:04 AM
jordoza's Avatar
I agree with everyone here. I wrap the cast manifolds too but it isnt really necessary I just like the way the lava wrap makes it all look. It hides my roll of dimes, nickels and filled holes possible pennies and stuff welds too. Lol.
Old Dec 19, 2022 | 11:26 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'm running a turbo blanket and the exhaust is DEI wrapped.
Old Dec 22, 2022 | 09:38 AM
forcd ind's Avatar
I usually wrap everything hot, I even wrap the cold side if its where the radiator can blow hot air on it. Its more about not melting stuff around it. This time I tried those expensive coatings, I dont think they worked better than wrap, so I wrapped them.
Mainly just love picking fiberglass or whatever out of my hands when working around the stuff, lol.
Old Dec 22, 2022 | 10:07 AM
275Camaro's Avatar
Thanks for the responses.
Old Dec 22, 2022 | 10:49 AM
LS1Tech Co-Founder
I've thought about having my pipes coated and it's still a possibility, but I'm going to wait and run the car at the track in the spring and see if there are any leaks. For this reason I won't have stuff coated black because it would be harder to see cracks and soot marks.
 Michael S. Palmer
