Pump gas guys beware... Fuel rules have changed.
Old Jan 12, 2023 | 12:24 PM
Forcefed86's Avatar
Default Pump gas guys beware... Fuel rules have changed.
Old Jan 12, 2023 | 03:27 PM
Formula934's Avatar
Great video but least of our worries with this administration. I live in Massachusetts and our recently elected LGBTQ governor (I only say that because the news keep making it a point to point it out) has nominated the first ever climate chief to wage war on fossil fuels.
Old Jan 12, 2023 | 03:31 PM
Forcefed86's Avatar
Not huge for most unmodified cars. But for the pump gas turbo guys… it could cost a motor. Even the base fuel used to make E85 has been downgraded with no real regulation. Criminal activity if it destroys someone’s motor. Esp. since they didn’t tell the public… pretty scary stuff!
Old Jan 12, 2023 | 03:42 PM
Formula934's Avatar
I run 93 pump + 100 % meth on my prcharged car but I also run boostane as well on top. I run only shell vpower 93. Seems like corners are being cut in all sectors of the economy due to the plandemic
Old Jan 12, 2023 | 05:34 PM
275Camaro's Avatar
Funny how they spoke of white papers, etc. but did not show any data. I see other YouTubers posting gasoline doomsday videos every other month. I would have to see real data.
Old Jan 12, 2023 | 07:20 PM
mk3cn4's Avatar
In this case if you go the actual YouTube page for that video they list bitly links for the articles and data, will paste real links below. I may try to read those when I get time too.
Maybe it's my comprehension, but their back and forth sure polluted the message and I'm not sure I totally understood it.
Can someone more knowledgeable than me confirm that their point was this: "Different regions of the US had gas recipe restrictions lifted for Covid, and pump gas in many regions had much more Ethanol than usual for that season's recipe, because it diluted the real gas so gas companies could spread it thinner and therefore make more gasoline available to everyone (which also made them more money)."
...is that what they are saying?
So that means if you tuned for 93 with, say, 8% ethanol, and then it changed to 93 with 18% ethanol, then your car would run "leaner" and if you didn't have KR to catch it then it could damage the engine? I may have that backwards but would like to understand it if someone feels like explaining it like a real person and not like these drama queen youtubers.
AAA Fuel Quality Report: https://www.aaa.com/AAA/common/AAR/f...ull-Report.pdf
U.S. Energy Information Administration Article: https://www.eia.gov/todayinenergy/detail.php?id=54839
2022 EPA Fuel Waivers: https://www.epa.gov/enforcement/fuel-waivers#2022
U.S. Department of Energy E15 definition: https://afdc.energy.gov/fuels/ethanol_e15.html
U.S. Department of Energy Flex Fuel Information: https://afdc.energy.gov/vehicles/flexible_fuel.html
Old Jan 12, 2023 | 08:34 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
That was my takeaway MK.
These guys kinda talk too much and I still have 11 minutes left lol.
Old Jan 13, 2023 | 05:39 AM
forcd ind's Avatar
From a legal point, I would think they have to post the accurate % content. A station around me that sells E85 just says 50-85 % eth, lol. I test it. The diff Holley systems I have used with a flex fuel sensor have always read 8% eth, not the 10% shown on the pumps, never actually tested it though.
Old Jan 13, 2023 | 09:01 AM
Forcefed86's Avatar
Def. long winded! lol
They have links to the documents on the youtube page. Basically says that in the time of the Covid crisis they could freely blend what ever the hell they wanted in the fuel due to shortages. Yet not tell the public what blends/additives they did or didn't use.
Old Jan 13, 2023 | 02:21 PM
RonSSNova's Avatar
https://www.enginelabs.com/news/what...l-in-pump-gas/
This at least puts it in words so you don’t have to listen to those goombah’s.
If running a Holley or other wideband system it should compensate nicely on its own. We are only talking a few percent here.
Factory ecu guys like me prob ought to tweak the fueling.
Although I run E85, so I don’t worry about it. I do check my fuel.
FWIW, ran my best ET last summer in my C5 which would have been on this new fuel. It’s properly tuned, so I don’t see an issue with the power end of things.
Ron
Old Jan 13, 2023 | 02:27 PM
Forcefed86's Avatar
Def. has more to do with people running pump gas tunes on the edge. Very few cars have an ethanol sensor and without it there's only so much closed loop correction can handle. Also older vehicles aren't designed to run on over 10% ethanol either. The fuel system material isn't compatible. No telling how high the percentages went as they aren't regulated. Not to mention there is money to be made running higher ethanol blends since its cheaper. Also can be region/gas station specific as there was no one policing this at all. Some areas of the country may have been affected very little... Others a lot. My only real gripe is that the public wasn't told. Nothing on the news, no notifications on pumps etc.
Old Jan 13, 2023 | 03:36 PM
GMCGreg's Avatar
Thanks for bringing this to our attention, agreed that vid is about 30 min longer than needed. This could easily explain my tune problem while on the power tour last June . Up here in Canada I usually run 91 octane 0% E. Readily available. For the tour I bought a tank of " up to 10% E " which was probably less , tweaked the tune a bit and thought I'd be good , get down to Tennessee and it's going very lean , was already cruising a little lean on purpose. Had to break out the laptop , could have been bad. Definitely looking into a flex fuel sensor for any future trips stateside. What's everyone using for a sensor ?
Old Jan 13, 2023 | 06:49 PM
truckdoug's Avatar
the guy with the glasses is Ren, the big guy is Stimpy
Old Jan 14, 2023 | 09:52 AM
mk3cn4's Avatar
I am now REALLY seeing the value of being able to have a computer watch and adjust at WOT. All I got is a manual AFR gauge and a factory PCM which obviously can't do that. For those who may not know, stock computer and tune blindly dumps a fixed amount of fuel based on a table at WOT, other than having KR possibly save you, that's basically it.
I "was" tuning a turbo on 87 before the track closed for the season. Paused that for the winter, been using 93 with somewhat conservative tune for my DD since it's been relatively cheap and wanted peace of mind.
But it's really enforcing the point others were making to me that riding on the edge of an 87 turbo tune could be a big mistake for this exact reason. If I hit a gas station like they describe with hugely diluted 87 fuel, it could very easily kill my engine apparently if I understand this correctly.
Not that it matters during the winter anyway LOL... even with a conservative tune I have almost zero opportunity to go WOT here in Pennsylvania with the cold hard all-season tires on gritty road surface. I can't do WOT even on a high roll right now without spinning. I barely go into PE at all LOL
Old Jan 14, 2023 | 01:31 PM
RonSSNova's Avatar
Ha! I remember those guys!
Old Jan 14, 2023 | 05:03 PM
n2xlr8n66's Avatar
I'm using the GM 13577394, based on good reports from the e85 / turbo crowd.
Old Jan 14, 2023 | 08:13 PM
Forcefed86's Avatar
Used the $26 shipped cheapy china sensor. Worked well for 3-4 years I had the car. Amazon has the ACDELCO 13507128 for $53.
I'll say running them can be tricky. Can't run them on return and they are a restriction on the supply unless you parallel them in. I used mine inline with the factory pump to fill a surge tank. Then used big pumps off the surge. Worked really well.
Old Jan 14, 2023 | 08:26 PM
GMCGreg's Avatar
thanks for that , looking into that and setting it up in the tune , doesn't look too difficult but will be for me LOL
Old Jan 14, 2023 | 08:35 PM
GMCGreg's Avatar
Spoiler!
Is that the cheapy ebay sensor that can't go in the return? I thought that's how they all were used ? If the delco version can go in the return I'd spend the extra on that as I have a simple single pump system. I even have an AN -AN connection a little in front of the tank on both feed and return to allow easy tank removal/service , that would be an easy place to locate it. Thanks
Old Jan 16, 2023 | 07:29 AM
LilJayV10's Avatar
Why can't you run them in the return?
