Purge valve-boost?
I replaced the fuel cap about a month ago because the factory one no longer clicked tight. Used a crappy parts store one. Then I noticed when i started smelling fuel, the aftermarket one no longer would tighten. Seems as if the seal had compressed or something and I did notice a very small (few drops I guess) amount of fuel in the filler neck area. Temporarily added an oring to the cap until I got a new one. While I was at it, I changed the Canister vent shut valve. Which looked like it was ever so slightly leaking. Now all of this has me thinking. Being the purge valve is on the intake and sees boost, I'm wondering if this is either leaking past the purge or maybe the purge is open under boost causing it to smell like fuel sometimes when I get on it? Should I put a check valve inbetween the intake and purge valve? Btw, I do not have a leak, i checked checked and rechecked. Nothing is wet and nothing smells....only the canister vent valve smelled and the gas tank filler compartment.....
before I replied, I wanted to be sure……
been driving the car a couple days since replacing the fuel cap and the canister vent valve. No more fuel smell. Just to be sure I went put fuel in it too. I’m certain there was no leak. Something kept blowing the seal on the gas caps. My guess is the vent valve was not venting. I think maybe having a check valve on the purge may help from blowing out the vent valve again.
something I’ve noticed. The car runs much smoother and my afr is now at 11.2:1 instead of 10.8:1. Why? I’m not sure. My thought is the tank was being pressurized. It seems to pull a good bit harder at wot too.
Andrew
