402/1500sl power #s.
Now with the same car I had a fully built 402 put in with the same mods. This time the car only put down 700whp/597trq on e85. Revved it up to 7k rpm, and made 8/9 lbs of boost. (I know bigger engine lower boost/ more air to feed)
All dynos have been dynojets. I know dynos are used as tools, and will have variances. But looking and reading and comparing builds with similar parts, seems like it's in the low end.
I was told fuel system duty cycle was at 96% (not injectors) which doesn't sound right since the same fuel system can handle 800-830ish on e85.
What am I missing here?
Fi Clinic 1200cc. I don't have logs unfortunately. Will 26 Ci make that much of a a difference?
here's some other builds with similar mods, but on pump and meth. 1500 unit though (Max rpm 55k and 950cfm), not the sl (52k/900cfm)
https://ls1tech.com/forums/forced-induction/1493670-402-novi-1500-results.html
https://www.corvetteforum.com/forums/c6-forced-induction-nitrous/3702994-how-much-hp-can-a-novi-sl-1500-can-handle.html
Usually that's reflected in the IDC but can also be a delivery problem to the injectors.
I added larger pumps and feed to my setup and dropped my IDC considerably.
this is what he sent me.
Hey its John this time as Jake went home for the day. We just Finished up on the dyno, earlier we were only seeing 8-9 lbs of boost but the brand new belt just needed a bit of an adjustment, and that netted us another 1-1/2 lbs of boost. Its not common to lose some boost going to the little bigger motor and a more efficient Camshaft, When jake first reached out to you it was only making 630-640 but ended up right at 700 on our dyno. (which yes it a bit of heartbreaker dyno) but as we tell every customer a dyno is just a tuning tool and to not be hung on numbers, especially with some of the astronomical numbers we have seen and been told by other shops in the area..
Regardless, were 700hp and 96% Duty Cycle (which is not the injectors now obviously but is the actual pump/supply of the system thats at its limits). Pressure drops/fluctuatues a bit after peak tq once it gets into some rpm/boost we i kept it on the safer side of timing as well.
Last but not least, your IAT's are climbing tremendously.. Ambient air being 68 Degrees in our shop (Car is reading 70-72 before the pull, and ending 119 Degrees by 7kRpm). So its also a large suggestion to get a better intercooler on this thing as HIGh IAT's and Timing (plus Running high duty cycle) is just asking for problems.
Therefore i would look into doing the Fuel Pump assembly, intercooler and then pulley down to get some more boost out of it for Future Mods. I cant remember but i believe when you and i spoke a while ago you had or were getting another blower for it (unless that was someone else at the time) but bumping up the Blower would just make everything overall more efficient.
Were gone for the day today, i would like to do one more cold startup and driveability log in the am before we release but everything for the most part went well and we can chat tomorrow once were in.
I had the same situation with my car, with FIC 1000cc injectors my IDC was at 75-80% at 10 lbs. of boost on a 5.7 with a S484 so knowing that I wasn't making 1,000whp wheel at that boost level that I was out of supply.
New, larger pumps and a larger feed brought my IDC down considerably.
What is your fuel system setup?
Also, I'd log IAT's while moving and reassess, A2A IC's tend to heat soak on the dyno without really good ventilation, 119 degrees on E85 wouldn't concern me all to much either.
I have zl1 pump, and dsx aux pump (255lph walbro). With those 2 pumps and tuning the stock fcpm, that can support 800-850whp, maybe more.
Your feed from the pumps should be -08an at minimum on E85 if not -10an.
Have you checked your filters yet?
Checked power and grounds?
with the zl1 pump and FPCM tune alone nets 550-600.
Also your intercooler situation.
I think that's okay for now. I would leave it alone.
I think for the fuel pump situation, don't folks sell dual drop in setups?
2nd shop, waaaaaaay better. Made the car run like butter. Tune was good, smoothed out everything. Then my engine blew.
3rd shop put in the new engine and is doing the tune.
I've looked into doing a drop in, but for the blower I have/the power goal I wanted I have the fuel system works fine with it. Not looking to crack 1000whp just yet.
Overall happy.
Question: oil pressure is hovering around 60, and pegging 69/70psi. I haven't really looked at that part of the instrument cluster, but is it normal? Also, stick with 5w30 synthetic, or change it up?
