Built engine - turbo suggestion
Old Apr 2, 2023 | 09:51 PM
67chevelleLS's Avatar
Default Built engine - turbo suggestion
Hi guys,
I may buy an lq9 that was built few years back, never ran. Has a BTR stage 3 cam, wiseco pistons, eagle rods. Compression I’m being told is between 8 & 9. As it’s been a few years the builder doesn’t remember.
my power goal atleast for now would be max 650-700whp on pump.
Would a Precision turbo 7675 t4 .81 ar work good with this setup?
Old Apr 3, 2023 | 07:06 AM
LS1Formulation's Avatar
Compression is WAY too low. Those are 1980's turbo numbers. I wouldn't go under 10:1 on an LS with a turbo. Cam is also way too large. That engine is a recipe for absolutely no bottom end power and for power to come on like a light switch around 5500 RPM. It will suck to drive. A 76/75 with a .81 A/R is too small for a 6 liter, IMO. The turbo would start choking off right as you got into power. Something that size with a 1.25 A/R would be minimum, in order not to choke off the engine due to lack of exhaust flow.
Old Apr 5, 2023 | 09:32 AM
C5_Pete's Avatar
Also, if it’s been sitting, was it properly prepped for storage? What do the cylinder walls look like?
Old Apr 5, 2023 | 11:23 AM
sewerpickle's Avatar
S475 in a T6 would be a minimum.
Old Apr 5, 2023 | 08:40 PM
It’s completely assembled now but from the pictures that I see, looks good. It’s stored in a shop with room temperature. About 3-4years I believe.
Old Apr 6, 2023 | 09:06 AM
Forcefed86's Avatar
There is ABSOLUTLY nothing wrong with that a 9ish to 1 compression level. Which is the most likely. If the motors together and healthy, zero reason not to run it. Esp with those goals and pump gas.
I doubt its anywhere near 8:1 as they would have to intentionally run it with an odd combination to get it down that low. (big dish or huge CC heads). What heads are on it? Use a bore scope and see if the pistons have a huge dish. Can also do a static comp test since you know it doesn’t have some huge high overlap cam in it. Will give you a good idea anyway. 170-180’s is “normalish” in most cases.
You lose roughly 4% NA hp going from 10:1 To 9:1 and pick up roughly 6% per pound of boost. So all this bandwagon BS around night/day differences between 9:1 and 10:1 is nonsense. Its less than 1psi of boost difference. I’ve run 7.8 to 10.5:1 in turbo setups. The trade off is a MUCH larger tuning window and more power potential at like cylinder pressures vs a tiny bit better response. *IF* you run E85 and are starting from scratch, I agree something closer to 10:1 may be optimal depending on the goal. But its FAR from necessary for a s 700ish hp 6.0.
I’ve run an 8.5:1 5.3 (gen3 even) clicking off 8 sec quarter miles times and easily lighting off the turbo on the line. What more is needed for most? You just need the right converter/setup for the job.
.96+ T4 76/75 precision turbos have made more than your goal on 6.0’s. Depends if you want a drag car or a quick spooling street toy. Personally, I don’t’ believe a single T4 belongs on any LS. I’d look at the S475 T6. Or if you really want a T4, they modify the Borg 1.25T4 for the larger 87/96 exh wheel. Would prob be the same or similar price to the Precision unit and be 2x the turbo.
Old Apr 7, 2023 | 02:55 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Since it's built is it .030 over or something like that?
Let's just say it's 8.5:1 with dished pistons. You'll be fine.Tuner should be made aware of compression they can probably add more timing in down low.
I'd only run a mid frame T6 in any new build, if you get the itch to go bigger you won't need to redo the kit.
Old Apr 8, 2023 | 08:20 AM
Old Buzzard's Avatar
"now but from the pictures that I see, looks good'.
That's reassuring.
Take it apart and do it right.
