New build need suggestions
Old May 27, 2023 | 06:57 AM
Kiker4923's Avatar
Default New build need suggestions
Back story I've got a gen 3 lm7 I had a stock block reworked by machine shop they put .20 flat top pistons and stock crank back in I put a stage 2 btr turbo cam with 243 heads tbss intake 78mm turbo the lifters spun in the tray and scarred my cam so now I'm rebuilding it I wasnt happy with the power im wanting more hp I didn't get it to a dyno before it spun im thinking it made 4-500 hp I'm wanting to be closer to 8-1000 hp what would be the best route to go to achieve my goal this will be strip only truck I don't have an unlimited budget so I'm wanting to do as budget friendly as I can
Old May 28, 2023 | 05:43 AM
Kiker4923's Avatar
Anybody
Old May 28, 2023 | 01:46 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You think you were making 500rwhp with the turbo?
If so, there was an issue, boost leak, could be a few things.
Old May 28, 2023 | 02:58 PM
Kiker4923's Avatar
Yea definitely had problems somewhere that's why I'm starting from scratch this time just needing suggestions on a direction to go in
Old May 30, 2023 | 01:45 PM
LS1Tech Co-Founder
I'm running a 5.3 LM7 SBE with a 85mm T6, and I figure it's gotta make 15 psi to make over 700... Double the air so to speak.
Are you using a boost controller, or just wanting to see what it will make without one? For example mine with the boost controller off will make 14 psi at 7100.
You might have boost leaks, might need to go over stuff.
Old May 30, 2023 | 02:02 PM
Kiker4923's Avatar
I run the terminator x ecu and a 4 port solenoid with onboard air I don't think I had leaks but that is very possible on the new build I'm running all new piping so hopefully I won't have any leaks in running a Ebay turbo 78mm I'm thinking maybe it is junk and not doing what it should
Old May 30, 2023 | 02:57 PM
LS1Tech Co-Founder
Yeah will need to check it. A great 78mm will make 1000 and a crap one I don't know.
Old May 30, 2023 | 05:57 PM
SAPPER's Avatar
Well with wanting that kind of power on this build. A stock crank will hold you for a limited time as will a stock rod. You could continue with the crank but need at least forged rods and pistons and balanced to within a gram or so to be reliable.
After that, then get some very good flowing heads to move all that air. This can all be done for under $4k since you have to pay for machine work and assembly.
But you will have a very stout bottom end that will handle 1000hp and live.
Old Jun 1, 2023 | 09:17 AM
Kiker4923's Avatar
What's rods and pistons should I go with to Keep it strong but in budget
Old Jun 1, 2023 | 09:47 AM
Black_Sunshine_99's Avatar
The crank wouldn't concern me, but the Gen III rods are not ideal, if he's gonna go for 1,000hp I'd at least put some Gen IV rods or AM rods in.
I'd price everything out and then look at pre-built short blocks as a lot of times they are a cheaper route overall.
A 5.3 and a nice billet 7875 like the new VS racing unit will get you pretty close to your goal, if its a track only rig, I'd look really hard at going to a T6 platform.
An S4xx T6 style turbo will get you to your goal much easier with the ability to upgrade as you go faster.
Old Jun 1, 2023 | 09:59 AM
Kiker4923's Avatar
So you think with stock bottom and. 20hyper pistons could hold up to enough boost to get close to 1000hp
Old Jun 1, 2023 | 10:15 AM
Guys have been doing it with SBE Gen IV 5.3's for a while now, with your current setup I'd go for 800hp but 1,000hp is asking a lot for the Gen III rods imo.
A decent billet wheel T6 turbo in the 75-80mm range with a Gen IV 5.3 would get you there, VS makes some good ones but if you can score a used Borg would be even better.
As long as you don't get greedy with timing at peak torque and give it plenty of RPM it'll live for a while.
A Gen IV iron 5.3 is cheap and will take a ton of power, Summit has a rotating assembly that would make it more reliable and stretch it out into the 1,200hp range which then the block becomes the weak point.
