Pulley combo thoughts?
Old Jul 6, 2023 | 09:59 PM
02redchevy's Avatar
Default Pulley combo thoughts?
Went to pin my crank.. crank isn't having it..(Just wont drill and keeps wanting to push the drill bit crooked) so I will use the keyway on the crank(thankfully it has one)....
Build:
LSA on a forged 6.0
BTR Cam: 226/231 on a 113, with .600/.610ish lift
LSA heads
9.5:1 compression
Looking for a balancer/pulley recommendation.
I currently have truck accessories and would like to keep it that way as I am using LSX innovation bd15 set up that's already ready to go.
I will be using a 2.45" upper so if I can swap pulleys in the future with the lower that would also be a plus. My goal is 550-600rwhp
I was thinking... Innovator West truck 15% overdriven.(https://www.tickperformance.com/inno...-15-overdrive/) which says it's 8.5" That should put me around a 3.47 blower drive ratio which I plan to spin to 6400(22,208 blower rpm) to 6700(23,242 blower rpm). Any thoughts or input?
Old Jul 7, 2023 | 05:11 PM
02redchevy's Avatar
decided to cut my losses and eat the 500 I wasted... going to go to an LSA style accessory drive
