72 RivieraTURBO choice
Have a 72 Riviera with a 475 fwhp LS2
4l80e with a Protorque 3200 stall converter with a 3.5 9"out back
Thinking it's time for a Turbo I'm thinking S400 75mm comp 83 turbine (single) looking to make 800 ish at the flywheel
I've researched the **** out of it but can't decide on which exhaust housing would be best for my street driven car !!
Does anyone have a similar build or some solid advice . BIG thanks for your time John, Liverpool England
Easier to package, costs less and will hit your goals easily.
If 800hp is your starting point with more in the future, then go with the T6 variant of a S4xx with a 96mm turbine.
You can start small with the S475 w/ the 83mm turbine and the beautiful part is when you want more and that turbo is insufficient, a larger S484 with the 96mm turbine will bolt right in.
I'm running an S484 w/ the 96mm turbine on my LS1 and TH400 trans and it doesn't take much to get it rolling, a little footbraking while rolling and it lights off fast.
S400 compressors are cheaper by a good amount
I don't want the car to come on too early so I'm guessing the t4 divided at 1.10 a.r
( T6 means bigger exhaust pipe which is like to avoid ) ?
4" down pipe to the cutout and neck it down from there to the mufflers for street use.
T6 is just the mounting flange type, yes its larger than a T4 but you want that because LS engines move a lot of air and your upgrade options for T6 are way more plentiful than T4.
Also, if you can swing a billet wheeled version that is the way to go.
