Boost control question from a newbie.
Mike
You can also use/build a manual boost controller with a check ball and a spring. Or a simple boost switch and pneumatic valve.
5psi isn’t worth turbocharging IMHO. But if that’s really what you want. You will likely need a custom or clipped wastegate main spring. Something that opens around the 3-5psi range with shop air on the bottom side. Do that first.
Then build this… And put it inline on the bottom. That will keep your gate closed until boost can unseat the ball valve.
https://speedracer90.tripod.com/mbc/
Or use a standard vac solenoid and boost switch set at 5psi to open at your desired boost. That will do the same thing.
Mike
