2003 Sierra sycloned
ive had cheap converters ($200), mid level ($1800), and many in between and in my experience the extra spent on a converter has a much larger day-to-day impact on a hot rod than camshafts, turbos, compression ratios, or just about anything else besides tires.
this hobby isnt for everyone though, and some would rather have pretty wheels or fancy paint. thats what makes the hobby interesting.
One car, one combination and a series of converters looking at rated stall vs actual stall, ET and MPH 1/8 and 1/4 mile, coupling capability (shift drop), heat generation, top end slip and dyno pulls for fun.
Give the torque converter companies accurate data and see who does it better.
I've had 6 different converters of varying degrees of stall over the last 20 years of owning fbodies (6th fbody now), and I'd always have to Google for others who list what they "really" stall at X power level etc. and scale accordingly and hope I guessed right.
I'm talking about off the shelf converters under $1k.
My worst surprise was going from an Edge 3200 to a Summit Racing 3200, the Edge 3200 IRL allowed way higher revving and allowed great street launches deep in the powerband, but the Summit 3200 would not even break the tires loose when nailed from a dead stop sometimes. The Summit "3200" would only let me tach it to 2800 MAX on footbrake pushing it hard as I could, and drove like stock where an 800rpm idle was enough to putt putt around parking lots idling. Not true with the Edge or my new Yank, they were loose down low and only moved with throttle. Unexplainably the Summit seemed to still give the same typical 5 tenths benefit at the track for me, but I have totally stock suspension/shocks/everything and couldn't really gain as much as you guys with your sub-1.5 sixties LOL.
I agree with what ****** is sorta implying... We need some common standardized way of measuring this better than "3200 stall".
i hate calling companies to waste their time and mine asking questions as much as the rest of us, but converters its gotta be built to your combo or you need a cookie cutter combo and some luck to get something good.
I would want to give them the opportunity to put their best foot forward so price would be a factor, bang for your buck as it were.
Then run the car through the tests mentioned earlier and collate the data.
I agree, the rated stall is not the way to select a converter, from my own experience I had a Redneck Converters 3,500 stall behind an old school SBC 350, and it would stall around 3,200.
Put that same converter behind a solid roller BBC 454 and it would flash over 4,500 rpm easily, it was unexpected but ended up being pretty fast and a ton of fun too lol.
BUT, someone with good suspension and sticky tires would certainly be able to push the Edge further greatly outperforming the Summit IMO, and both were 3200 stalls.
For FUN Factor its not a good thing away from the track. IRL with the Edge I could floor it on a roll and it'd really kick up to the powerband and throw the car sideways, I know the Edge outperformed the Summit in those cases as the summit woudn't let the engine rev high enough to hit that power level, just kinda bogged.
And let's face it, it's pretty dang cool to just GOOSE IT for a second rolling at 5mphs and it spin the tires... no chance of that with the summit one. gives the illusion of having way more power than you do LOL
Yea sorry it does sound like I contradicted myself, but the edge just felt like the car had so much more power even though I didn't have the traction at the track to take advantage of it in my case. The two "3200" stall converters were miles apart in feel and function.
My problem now is that I overcompensated the other way this time, I went with a Yank PT4000 but then went turbo not long afterwards. Didn't plan ahead. My poor car sounds like a golf cart going down the track. But it seems to be doing OK. Heck maybe I'll throw that summit one back in now :-)
For catchup, my 2.0 was on the street. I’ve since been trying a lot more footbraking and I can get positive boost, but I haven’t draggyed since trying some of these. I suspect it will improve yet on the street. More to follow.
Pretty cool to do that at 70+ mph too 🍻
Now with the turbo and 100 extra horsepower I believe I'm leaving a lot on the table with the slip of this 4000 Yank because I think it's too loose and I'm pushing through too much. Sounds like a golfcart going down the track with shifts almost undetectable. I expect I could have chosen better (tighter) with a turbo car. It's not so bad it's worth changing but it would not have been my first choice knowing the power numbers I would end up with, trapping over 120.
Sorry I don't remember the numbers of the flash offhand, but it was high enough to get deep into the powerband.
i thought this truck was awd? ive had an awd rcsb for a long time with the cheapest tires on amazon and rarely had traction issues at 16 psi
It gained almost 90 peak from the previous with as much as 200 in the middle of the range. It was as high as 592 but turned it down because it pickup up some more boost on the street. Faster spool too. Still 10 psi. E85.
Nice!
