The Turbo TA is BACK!
Old Oct 7, 2025 | 12:03 PM
  #121
Broke EF's Avatar
Yesterday they decided to take the car for a nice little walk
Then he brought it back inside before the rain to put it back together
Old Oct 7, 2025 | 12:05 PM
  #122
ScreaminHawk's Avatar
Car prolly needed the walk after how long it's been without a powertrain
Old Oct 7, 2025 | 12:59 PM
  #123
Broke EF's Avatar
I pulled the drivetrain out like a week ago LOL
Old Oct 7, 2025 | 01:18 PM
  #124
still too long lmao
Old Oct 20, 2025 | 10:56 AM
  #125
Broke EF's Avatar
I am copying and pasting this from another forum, so its a bit of repeat.Many of you know I bought back a car that has a lot meaning to me. I spent about a year trying to decide what to do with it. It already had a 25.5 cage in it (good to 7.50), but I never fit in the car very well. It started as an 8.50 cage kit which always leaves some room for improvement, and then was built around my friend who is about 5'10" or so. Me being 6'4" and quite a bit bigger, it was basically a no go for me. Long story short I decided to have a new chassis built, and went with J&E Chassis works to have it done. After about a year, I got the car back.
It looks pretty good from a distance, but when you start getting up close and personal you see things such as.
Passenger side roof rail attached to the a-pillar
This is across the top of the windshield
Floors not closed in (this is drover side under the master)
Passenger side
Holes cut in the tops of the wheel tubs. This is passenger side
And driver
Powder coated over the drain plug for the rear end
Burn in new carbon dash
Hard to see, but the 4 link brackets are not sealed off. Also some great beadroll work
An example of the holes for the midplate
Looking at the firewall after paint
Detailed bead roll work
This is the engine side of the firewall on the driver side of the car
This is the cabin side of the firewall on the passenger side.
Hard to tell, but the sleeve for the mid plate bolts is crooked
Of the work that was actually done, some was really good. A lot of the cage work is very nice, and fits up very tight. Once you get into finish work though, that's another story. I stripped the car right away so I could have the chassis painted, something that should have been done already IMO. Since then I haven't done anything. I got it back home, put it on the lift and just ignore it. I was actually showing it to the old owner yesterday. I ended up getting mad about it, put it back in the air and went inside.
Old Oct 25, 2025 | 11:52 PM
  #126
Broke EF's Avatar
I finally decided to go head out to the garage and mess with the car some today. I kind of wanted to go over some things, and tinker a bit. So I started with taking off the driver door
I threw the dash in more to just get it out of the way more than anything.
I figured that was a good idea, so I threw the door carbon in to get it out of the way as well
Then it was time to get a bit more serious and work on getting the rear end out of the car. I started by using the pro jack mounts on the 4 link brackets to hold up the car
Then I just worked, no pics, and just like magic the rear was out! I also threw in rear carbon pieces real quick.
After that I put the rest of the carbon pieces in before calling it a day. Here is the passenger floor, I didnt take a pic of the rear stuff
The main thing was to get the rear end out so I could put the tubs in. However, I am not sure if I am going to replace them or not, which is true for all of the carbon work. Well that's all for today, I recorded some stuff as well, so maybe I will throw together a video as well.
Old Oct 27, 2025 | 09:06 PM
  #127
Broke EF's Avatar
Its been a minute since I did a video, but here it is
Old Oct 31, 2025 | 11:29 AM
  #128
Carbon surrounding the cage looks cool as hell
Old Nov 2, 2025 | 07:41 PM
  #129
Broke EF's Avatar
What a wonderful weekend of working on this gem. Lets start with a pic of the back section just because.
Anyway, the main thing I wanted to get done was get the engine back in the car. You know, this thing
It was a massive pain in the ***, but I managed to get it in without losing a finger!
With that back in, I wanted to get the turbo in, so I did.
Here you can see, the turbo is rigid mounted to the frame
As you can tell. its not very far from lining up. I could at least get it closer, possibly even connected if I had a second set of hands. This turbo is decently heavy, so trying to move it around and bolt up the mount at the same time was a pain. Anyway the point was to see where the engine is positioned to see if I need to move it. I have to talk to some people who are a lot smarter than me to see what to do there. Hopefully between the motor plate and the mid plate we can get it set right.
I also threw the rear end in, but thats not very exciting.
It almost looks cool
That was all for Saturday, which brings us to today. I wanted to get the TBM brakes installed on the front. I wasn't sure how to lift the front with the back still up on stands. This worked out pretty well though.
Gross
I got them taken off, and cleaned up the hub all nice. Then I assembled the hat/rotor before grabbing the caliper bracket.
Too bad this is the wrong kit!!!
That was wonderful. Turns out I need a completely different kit that is also more money. Now I need to decide if I want to make any other changes at the same time. I was already thinking of doing drop spindles, I guess now would be as good of a time as any. The other option would be to just say **** it and front half it, but that seems pretty drastic.
That is all for this weekend. I should have a video up this week sometime where you can watch me struggle getting the engine in. Keep an eye out for that goodness.
Old Nov 3, 2025 | 08:08 AM
  #130
Broke EF's Avatar
Thanks! Hard to go wrong with black and carbon I am still not sure if I am going to change it around or just leave it.
Old Nov 5, 2025 | 12:08 PM
  #131
Car would also look sick in red imo red and black just works
Old Nov 6, 2025 | 12:59 PM
  #132
Broke EF's Avatar
The best thing that happened to this car is that it got painted black I am upset some red is coming though!
Old Nov 6, 2025 | 04:48 PM
  #133
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Trying to remember, the driveline the car came with, single large frame 94MM and a 408 or 427. I recall it had a glide.
Old Nov 7, 2025 | 08:40 AM
  #134
Broke EF's Avatar
When Chris had it
Stock LS1 with 6 speed and stock rear
Stock LS1 with 76mm turbo, 6 speed, and stock rear
Stock LS1 with 76mm turbo, 6 speed, and MWC 9"
Stock LS1 with 76mm turbo, TH400, and MWC 9"
Texas Speed 6.0 (rods pistons), 76mm turbo, TH400, MWC 9"
LSNext iron block 427, 94mm turbo, TH400, MWC 9"
Sold to John with no engine or trans
LSX iron block 427, 94mm turbo, Power glide, MWC 9"
Sold to me with above combo. For now I am keeping the engine, trans, probably converter, and turbo. It of course has a J&E Fabricated 9" housing now. Long term I want to go big block with twins and back to a TH400, but to keep cost down I am going to use what I have and hope it works well. I will be redoing the turbo kit, probably getting rid of the truck manifold setup and the intercooler.
Old Nov 7, 2025 | 12:20 PM
  #135
Black_Sunshine_99's Avatar
When Chris had it
Big block and twins is the way.
There's a guy on YB with a 3rd gen, 555ci BBC and twin S485's making 1,800whp iirc.
Standard build with off the shelf parts, nothing crazy, its a total streetcar too.
Old Nov 10, 2025 | 08:54 AM
  #136
Broke EF's Avatar
You got that right!
I want more than 1800, but big block with twins is the cheapest and most reliable way to get those big numbers. There is a reason almost all of the top drag and drive cars use that base combo.
Old Nov 17, 2025 | 11:54 AM
  #137
Esser's Avatar
I think all of these things you pointed out are so crazy minor, it makes me question what the build purpose is. The amount of hours of pipe fit up, cutting, bending, and welding precision it takes to do what J&E did is immense. I think it is a little petty to point out all those minor things and bypassing all of the tremendous amount of fine work put into that car, it is obvious that you don't do that kind of work yourself so it's easy to point out items you see that look "bad" and not understand the work behind it. I always say, if you want things done a certain way then learn how to do them yourself. I don't even know J&E but i can tell you after looking at the photos of your car I wouldn't hesitate to take any car there. That is one hell of a good job they did!!
Old Nov 18, 2025 | 11:47 AM
  #138
Broke EF's Avatar
They are great, good luck! Let me know if you can get my parts back for me when you bring your car in.
Old Nov 18, 2025 | 12:11 PM
  #139
Sorry, totally disagree with you on this.
Paying a shop to build a car for you only for them to completely botch the tin work among other things and then letting it go because the cage looks good is wild.
This kind of mindset will just ensure shops like this continue to put out subpar jobs, if J&E can't do bead work, then they should say as much.
I don't know what the OP paid to have the work done but there should have been at the very least a shop lead at J&E who was checking this work and should have caught the poor bead work detail and if there isn't a lead then that tells you everything you need to know about J&E.
Old Nov 18, 2025 | 01:18 PM
  #140
Broke EF's Avatar
Agreed
The quality of SOME of the work is only a tiny bit of the overall problem anyway. I am more upset that almost half of what was agreed upon and paid for was not done at all. I would argue that things that were done, were not done 100% (no seat belt tabs, no paint etc.) Then we have missing parts to add to that.
I guess someone had to be first to stick up for the shop though. Maybe I just don't understand what it takes though LOL Stay tuned to see me not do this kind of work myself as I fix/finished everything I paid for.
