2000 TA TURBO BUILD (Psychotic)
Twin 340’s or triple 255’s with good wiring and obviously setting it up with an external regulator using stock lines will carry you pretty far. magnafuel will require a sumped tank. All of these things need to be carefully considered or you will be spending more money than needed. A 5.3 will take more punishment with its thicker bores. The LS1 unfortunately will not afford that reliably.
A nice quality, good flowing, and efficient intercooler plus a meth kit are two very important features that can not be ignored. You could do a cheaper A2W and get more out of it as well. I’m not trying to shoot you down in any way so please don’t take offense with my advice. This is coming from a realistic standpoint. Get a pump set up as mentioned, build it, and enjoy it. Set a goal/plan and stay away from the snowball.
The following users liked this post:
The BallSS (12-04-2023)
Gjohnsonws6 no offense taken I appreciate the advice. The ls1 does have stock bottom end but I have a gen 4 6.0 I'm building with forged pistons
I'm going to swap in but want to run the turbo set up on the ls1 until I'm done building the 6.0. The l000 rwhp will be on the 6.0 shortblock built for boost. The stock fuel lines will support 1000 rwhp?
Hotside just about done most of the welding is done. Only thing left is adding 2 wastegates, 1 02 bung and alittle more finish welding. Next on the list is to notch alittle of the subframe on pass side so i can unbolt the hotside without removing the manifold. Than I will order parts to fab up the coldside.
Pro Stock John (12-05-2023)
Started fabbing coldside, little trick to make bead in coldside piping after you cut pipe use a pair of electrical crimp pliers moon side up and crimp all the way around the cut side of pipe. Works pretty well. Still waiting for my intercooler and have to decide where bov will go.
What's the best spot to put the bov?
#34
Update got everything mocked up, downpipe finished and alternator relocated. Also welded the drain fitting into timing cover. I know that the balancer isn't pressed all the way onto crank didn't want to press it on for mock up. Also I know In these pics the belt rubs the water neck but I fixed that but forgot to take new pics. Next I will sandblast the timing cover, valve covers, intake and turbo housing and send them off for powdercoat. Than when tax return comes in will buy holley terminator x, digital dash and fuel system. Let me know what u think.
KnightmareLS1 (02-26-2024)
#36
Nice build, similar to what I'm doing except I went for an off the shelf Huronspeed T4 system. I will say, bang for your buck-wise, the complete F-body dual 340 fuel system from WS6Store gives you everything you need and then some. The only thing I'm adding is a Motion Raceworks flex fuel sensor holder with a dual flow path so I can plumb in my sensor in my feed line, which is -8. You won't need that on pump gas, of course. I went the Gen IV aluminum 5.3 route for an engine, because my LH6 block is one of the strongest factory blocks. 6.0s are known to get radial bore cracks with big power, especially with an overbore. Something to keep in mind for future plans.
Pro Stock John (03-01-2024)
#39
Big update
Got parts back from powdercoating member here mealonwheels does great work. Painted engine bay with por15, high temp painted and wrapped hotside etc. Only a few things left now need to get new turbo lines cause the ones I bought were too short. Got the holley terminator x all wires up and the rear battery just have to clean up the wiring a bit. Need to buy injectors and install my fpr and convert evap to return. Here's a bunch of pics let me know what u guys think.
weiland (05-08-2024)
