Little help with a little verfication
Old Dec 21, 2023 | 04:05 PM
teenycar's Avatar
Default Little help with a little verfication
Built up a mild lq4 with a truck Norris cam and springs and of course new and gapped rings with ls9 head gaskets. 317 heads for a friendly street/track tune. First turbo so I got a gt45 to play with. I know it’s likely a little small for the 6.0 but I’m only looking for 7-800hp. Plan to run a vsr 44mm wg welded directly off the gt45 housing close to the flange and more parallel to the flow rather than perpendicular. Still looking for an air to air intercooler. Blow off valve with be a vsr 50mm. Sizing ok? Cross over tube is 2.5”. Down pipe I’ll try and keep it as big as I can fit. I know it’s 4” but it may need to be closer to 3.5 going into a muffler. Anything to add.
