ls2 402 going boost
Old Jan 6, 2024 | 10:58 PM
Tgifraire's Avatar
Default ls2 402 going boost
So, i have an N/A 11:5 compression ls2 402 forged LME motor w/ 235 trickflow heads in my 2002 camaro. Im going boost now with a Huron speed twin turbo kit E85 stage 2 fuel system upgrade bosch #127 injectors. How much boost would ideal to run on this set up if it would be ideal/safe to stick with this short block. Plans are to be around 750-800hp.
Old Jan 7, 2024 | 12:32 AM
jayyyw's Avatar
Whatever is needed to make your power goals. PSI is just a measurement of restriction. Doesn't mean much until you know what turbo(s) are supplying the volume of air. Could take 20psi with a smaller turbo or 6psi with a big turbo, or two of them.
