Best turbo size for power/efficiency for 4.8l
Any advice would be appreciated!
https://briantooleyracing.com/btr-ge...orris-cam.html
@408GT Seems to be pretty knowledgeable in building the smaller displacement turbo trucks like you're doing. He also has a Youtube channel.
Are you sure it even needs pistons and rods? Most of the time, a new set of rings gapped for boost is all that's needed even if it's a high-mileage engine (200k+).
I’d have to argue that spending money on anything else is pretty pointless with a 400ish* hp turbo goal. Put a S366 on a bone stock untouched 4.8 and it will make more power than you are wanting on pump gas. Don’t even need an intercooler to make 400. VS racing S366 and be done. Its MUCH cheaper than going with an NA 6.0 or even a 5.3 and will perform better. Much more bang for your buck than going with a larger cube motor.
