EBC duty cycle.
Old Feb 25, 2024 | 11:15 AM
DETHS5THGEN's Avatar
Default EBC duty cycle.
I've been trying to adjust my GoFastBits EBC to get 15 lbs and was curious if that's possible with my WG and 8lb springs. My car has the Huron twin kit with 6766 T4s and the standard 45mm WGs. I'm at 70% duty cycle and at 12 lbs now. Should I crank it up more to get to my goal of 15 or am I too high on duty cycle? Does running that high of Duty cycle have any negative impact? I do have the smaller 3 lb helper springs available if needed. Thanks.
Old Feb 25, 2024 | 06:12 PM
GMCGreg's Avatar
Turn it up ! I'm single turbo and with just under 7lbs controller off , 15.5lbs at 78 ish DC with a aem tru boost. Been doing this for yrs with no issues. Varies a little with atmospheric conditions and did hit 18lbs by accident once, going to be turning it up this year
Old Feb 26, 2024 | 12:15 PM
Thanks! I'll crank up the DC.
Old Feb 26, 2024 | 12:37 PM
NicD's Avatar
7 Second Club
Just be aware that most solenoids are basically done around 80% duty cycle and going above that it won't really do anything. You can stretch the reactive duty cycle a bit by using a lower frequency but that is also limited in what it accomplishes. I don't recall what frequency the GFB uses though nor if it's adjustable...
Old Feb 26, 2024 | 01:13 PM
GMCGreg's Avatar
Can only say what mine is doing but boost definitely keeps rising past 80%
Old Feb 26, 2024 | 03:44 PM
NicD's Avatar
7 Second Club
The exception does not make the rule and every combo is different. You can get up around 90% at a low frequency like 10 Hz with a mac valve but most controllers are set up around 25-30 Hz which limits things to around 80% on most solenoids.
Old Feb 26, 2024 | 06:45 PM
GMCGreg's Avatar
On top of the electronic variables there's mechanical differences that will have an effect, such as gate size and placement, backpressure vs boost pressure especially when using boost pressure to feed the solenoid. I have no idea what frequency the AEM uses 🤷‍♂️
