How much boost are the 6 rib systems holding??
Old Jul 26, 2004 | 10:14 PM
Daily T/A's Avatar
Default How much boost are the 6 rib systems holding??
As the title states, my motor should be done in a couple of weeks, just wondering what the threshold for boost is with the 6 rib(including MM pulley and RR pulley? I'm looking for 10-12 psi, but if the system won't hold then I'll just upgrade to the 8 rib or SDCE.
Thanks,
Andy
Old Jul 27, 2004 | 11:54 AM
NA$TY-TA's Avatar
I was seeing 11 psi on my old setup with the MMS crank pulley and 4" blower pulley, but that was with a stock motor and shifting at 6200rpm. I ould go with the SDCE 8 rib kit like alot of us and never look back.
Kyle
Old Jul 27, 2004 | 11:55 AM
mdhmi's Avatar
I haven't had any problems with 7-9 lbs of boost. You might run into some problems doing 4000-5000 RPM clutch dumps at the track though.
Mark
