Help!!!!
Old Jul 27, 2004 | 11:06 AM
Green Thunder's Avatar
Default Help!!!!
Heres the deal.
2001 6.0 ported and polished heads, Manley sportsman Rods, Stock Crank, Diamond forged pistons...80mm throttle body, shorties blah blah...
Original Idea:
Take a turbo from a duramax and create a STS "Type" turbo set up..
Cant get enough info to determine if the turbo will work...
Idea #2
Scrap the Duramax turbo and go to a different turbo I already have
It is a T3/4 hybrid Garrett. After talking with different people I have been led to realize it is not big enough. I do not know the mapping of the turbo, all I do know is that it puts out 60lbs per minute. The part # is 715583-5006. I cannot seem to find the mapping on it anywhere.
Idea #3
Create a rear twin-turbo setup using 2- 715583-5006 turbos. Now I am being told that they might not flow enough exhaust even in a twin application
Can anyone help with the mapping of this turbo via the part #?
I appreciate anyones $.02
Thank you!
