Boost rated vacuum caps?
Old Aug 23, 2024 | 06:32 PM
4EyedTurd1's Avatar
Default Boost rated vacuum caps?
Rookie question, I know, the silicone caps I put on the 2 nipples off the throttle body didn’t last the first outing at 7psi. I could just stick some hose on the nipples and put bolts in them but looking for any other options
Old Aug 24, 2024 | 06:30 AM
TrendSetter's Avatar
i have had good luck with zip ties. i put two on the red cap in the picture, it hasnt come off at 19psi yet
same intake, other nipples i have tapped for 6-32 and glued a grub screw in.
Old Aug 24, 2024 | 10:45 AM
4EyedTurd1's Avatar
It’s not the issue of staying on, it’s the blowing the end out. I’ll try another with a ziptie instead of a hose clamp
Old Aug 24, 2024 | 10:54 PM
ScottStaypuff's Avatar
You could put RTV in the cap then shove it on to really plug it up. Then secure with a zip tie. I've done this before to make it a semi permanent plug.
Old Aug 26, 2024 | 10:23 AM
Black_Sunshine_99's Avatar
I think you're plugs are old and rotted.
I went and bought some AutoZone rubber vacuum caps and zip tied them on and never had an issue up to 16 lbs.
Know plenty of guys running twice that and never had an issue.
Old Aug 26, 2024 | 11:47 AM
4EyedTurd1's Avatar
Possible, I went and got silicone caps after reading somewhere about them holding up better.
Old Aug 26, 2024 | 03:22 PM
If you’re having trouble with soft caps, it only take a few minutes and a few dollars to get a tap that directly threads the ID of the nipple and some grub screws threaded in with sealant.
Old Aug 27, 2024 | 01:03 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
It is also not that hard to plastic weld nylon. Could just permanently close up unused ports.
