Info for bigger K&N Filters inside
RU-1785 Inlet hat
RU-1030 Inlet hat/Surge Pipe
BTW, I picked up 1.5 psi of boost taking the inlet hat off on the dyno, unfortunately I couldnt figure out anything better to do then the way it is. I'm sure ou guys spinning up the blower higher will notice much more of a difference..
Hence the inlet hat/filter restriction. Supposedly you need 4" straight out from the impeller at a minimum for max cfm flow for a D1SC at 62,000 rpms. I plan on taking my inlet hat off at the dyno and possibly the track as well.
But unfortunately on an f-body that little thing called the radiator/core support is in the way
I'm sure someone can move the radiator forward and get a better inlet in there it would make a big difference when you are spinning it up, that inlet hat is crap. I was going to make a velocity stack kinda thing with a screen for the track but never got around to it.. But unfortunately on an f-body that little thing called the radiator/core support is in the way
But if I were looking for big HP something needs to be done there.. Trending Topics
Thanks
Kyle
if you can get one of those filters for a 5 inch compressor inlet, please PM me
RU-1785 is $37.53 and
RU-1030 is $26.61
Not bad at all. Thanks for posting up the info.
Kyle
