humm, installed fuel pressure gauge and this is weird...
Old Aug 7, 2004 | 08:53 PM
Tiago's Avatar
Default humm, installed fuel pressure gauge and this is weird...
I just installeedd a fuel pressure gauge and when the key is set to on, I read 48 psi and with the car running 78 psi constantly. IF I get into boost the pressure will actually DROP to about 60 psi and stay there. It never goes above 78 psi, only down to ~60 under boost.
Im running a single walbro 340. Something makes me think I got a bad gauge or sending unit? The stock regulator would hold the pressure at 60 always otherwise no matter what...
I was gonna use the FP data to determine if I need to install a second 340 inline before hitting the track tomorrow but right now Im stuck with this problem...
Old Aug 7, 2004 | 09:07 PM
onfire's Avatar
Coal Mining Director
The regulator held 60psi with the stock pump due to the flow rate of the stock pump....more pump with the same restriction (stock regulator) = more pressure....78 does seem high even with a Walbro.
Old Aug 7, 2004 | 09:16 PM
Tiago's Avatar
I just don't know if Im really running out of pump or the gauge is screwed....
Old Aug 7, 2004 | 10:06 PM
MelloYellow's Avatar
Sounds like a messed up gauge.
