Summit Pistons
They're 2618. I believe Summit also has a house branded piston that is not in their Pro LS line, and that may be 4032.
I also considered getting this kit, my bore is 3.800 and this is the only kit I found that I can buy that has that size. Price really isn't any different then me buying separate but it does give me a piece of mind knowing I'm not verifying piston to rods specs as they match it for you.
The 4032 coated forged pistons you found were designed as a middle ground between stock replacement hypereutectic pistons and our 2618 Pro LS line. While we don’t currently offer 2618 pistons for an SBC under our brand, we do work with a wide range of vendors who provide 2618 options.
If you need help selecting the right pistons, feel free to reach out with details about your build. Key info like bore size, stroke, rod length, pin diameter, flat top or dome preference, and the compression ratio or cc range you’re aiming for will help us guide you to the best option. We’re here to help!
https://www.summitracing.com/parts/jep-170817-8
A budget-friendly alternative that matches your JE pistons is the D.S.S. Racing DMS-2-2407-40302618 FX series pistons, priced at $699.95. They also offer a version with upgraded XR pins DMS-3-2407-4030 for $879.95.
Remember, our CYBER promotion ends today. Get $20 off orders over $250, $40 off over $500, or $80 off over $1,000.
