Twin Turbo LS6 build
Old Jan 3, 2025 | 05:43 PM
Sands05's Avatar
Default Twin Turbo LS6 build
I’m doing a custom rear mount twin turbo kit on my v1 with the LS6, i’m putting in two 61/65 journal bearing turbos and I’m planning to add an oil cooler while i’m at it. The adapter plate I have to go right above the oil filter has a 1/8NPT outlet to provide oil for turbos. My question is if I use that 1/8NPT and run a -6AN that Ys off into two -4AN lines will my turbos get starved of oil (meaning I have to find a new location for the feed line) or will it be okay?
