Breaking up under boost
Old Jan 30, 2025 | 10:04 PM
Blayn.21's Avatar
Default Breaking up under boost
1998 C5 Stock LS1, 2 bar OS SD, 80lb injectors, 525lph pump, Hotwire kit, E85, BR7EF plugs gapped at .23, D585 Truck coils, MSD plug wires 10-11psi max.
Breaking up/misfiring under boost bad. AFR spikes to 20+ when it does this. Almost sounds like antilag and it spools my turbo up fast. Sometimes shoots visible flames aswell and sounds like gunshots. Ive replaced my wires, coils, and plugs. The very first pull on brand new plugs is the only pull that it didnt backfire on. Not sure what the problem is at this point maybe grounds? Starts happening at 6+ psi now, used to happen earlier but the truck coils seem to have delayed it slightly. I can roll into boost slightly fine up to about 5-6 psi before it happens. Any suggestions?
Old Jan 31, 2025 | 06:37 AM
wlink14's Avatar
I would be looking into plugs and wires first. MSD doesnt mean they are good. Grounds? Voltage?
What is AFR before it starts spiking? Losing fuel pressure? Genuine injectors and pump? We really need datalogs....
Old Jan 31, 2025 | 07:55 AM
Old Buzzard's Avatar
"Any suggestions?"
Yep.... Data log it and post the log and the tune.
Old Jan 31, 2025 | 09:48 AM
Black_Sunshine_99's Avatar
Agreed with log and tune.
At a glance I'd lean toward plugs and wires, BR7EF's might be too cold for what you're doing right now, I run those up to 14-15 lbs. on pump gas currently gapped at .022 iirc, E85 may need more heat at lower boost.
Maybe one step hotter plug and genuine GM plug wires, I've had issues with MSD plug wires in the past.
Old Jan 31, 2025 | 11:39 AM
AwesomeAuto's Avatar
What does the timing look like in the log when its missing? Does the AFR spike rich or lean right before it happens? MAP sensor reading vs gauge readings in boost?
Lots of questions here.
Old Jan 31, 2025 | 12:55 PM
forcd ind's Avatar
What RPM does it do it at.
Old Jan 31, 2025 | 03:15 PM
IGN-1A's Avatar
Default Grease your boots
Grease, Silicon, is used on the sparkplug insulators.
Did you use this item on your sparkplug boots ?
Old Jan 31, 2025 | 05:15 PM
Blayn.21's Avatar
Any RPM, it’s boost dependent.
 Michael S. Palmer
Old Jan 31, 2025 | 05:16 PM
Blayn.21's Avatar
I’ll send a log and tune in a second, it spikes lean to 20+ AFR. Map sensor reading vs boost gauge is pretty spot on
Old Jan 31, 2025 | 05:22 PM
Blayn.21's Avatar
No I didn’t, plug wires are brand new, had them on the car for 2 days now. Changed out coils and wires to see if it’d fix it.
The plugs are tuner recommendation, I asked if I should use a 6 plug and he said to stay with 7s. I had GM wires on it and it was still doing it. Just found out the old coils I switched yesterday for the trucks are knock off amazon coils.
Haven’t check FP yet, the MSD plugs are 2 days old. Just put them on the car. I just cleaned the coil ground yesterday, had old like heat wrap on it peeling off but was pretty clean. AFR before spiking is in the 12s. Will send log and tune in a second. I think i might’ve fouled my plugs out with the old crappy coils because the car did work when i put brand new plugs in for one single pull then it got progressively worse each time.
Old Jan 31, 2025 | 08:16 PM
Bbknucks's Avatar
Almost always plug wires... I've had enough issues when I didn't use OE ones I won't use anything else
The cheap coils are also unreliable
Misfire will cause lean readings
Old Feb 1, 2025 | 02:56 PM
Blayn.21's Avatar
I have no clue what my actual problem was but switching back to 93 has fixed it. maybe not enough fuel system for E
Old Feb 1, 2025 | 03:01 PM
Bbknucks's Avatar
Do you have a log showing injector duty and fuel pressure?
Old Feb 1, 2025 | 05:49 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You looking at the fuel trims and injector cycle OP?
Old Feb 3, 2025 | 11:25 AM
The last time this happened to me, it was plug wires. I used a multimeter to test the resistance of each of them and found a couple of duds.
Old Feb 3, 2025 | 11:59 AM
What kind of reading are you looking for?
Old Feb 3, 2025 | 12:04 PM
Other than consistency between the wires? Making sure that one of them doesn't have extremely high ohms. Even a cheap set should have less than 500 ohms between the terminals. Finding one with 8k ohms is usually an obvious sign of a problem.
Old Feb 11, 2025 | 08:20 AM
Old Feb 11, 2025 | 12:45 PM
IGN-1A's Avatar
Default NASCAR Tech
Carl Wegner stated the same "No Grease".
We were at Fontata, A GNW race, four cars with Wegner engines.
I TOLD him to use the grease I brought to the race, A Silicon base for SPW boots.
HINT: The track was wet from a night rain, I could see a mist as the group passed.
The next session was afternoon, the grease was used on all the team cars.
As I saw the LEAD CAR pass the Start/Finish I noticed it was a Wegner team car!
Thus a pole position and the rest of the field (not Wegner's cars) were very slow caused by an engine misfire.
Carl then "thanked me" by stating me as the Mad Scientist team member position,
Lance
