Duramax Intercooler Questions
Old Feb 2, 2025 | 04:48 PM
Jacob VH's Avatar
Default Duramax Intercooler Questions
I've got a 2005 Sierra 2500HD with a 6.0
Everything is nearly 100% figured out for the turbo installation except for intercooler... because it can get pricy!
I've been thinking of doing a Duramax Intercooler and I have a few questions because this stuff isn't all that clear online
- Is there much of a difference between the LBZ , LLY, LB7 intercoolers?
- Anyone know what sorta HP I can expect before IAT starts to jump up rapidly?
- Do I need to get a whole duramax rad support and rad to make this work or is just the intercooler sufficient for a direct bolt in?
Thanks
Old Feb 2, 2025 | 11:04 PM
1FastBrick's Avatar
The LB7 and LLY inter cooler I believe are the same with all aluminum construction. The LBZ is different and has a plastic tank on one end. That end, uses a special slip fit connection.
I haven't compared the the duramax to a gasser 2500 core support. They might be the same. They are however different from a 1500. The LBZ also has a unique core support for its application because it has a taller cooling stack from the previous LB7/LLY
Old Feb 3, 2025 | 08:51 AM
Jacob VH's Avatar
Originally Posted by 1FastBrick
The LBZ is different and has a plastic tank on one end. The LBZ also has a unique core support for its application because it has a taller cooling stack from the previous LB7/LLY
Awesome and good to here, I'm going to try and get a LB7 intercooler and rad of a guy. I had heard the hood was different on the LBZ as well, so I'll stick with what should work 100%
​​​​still wondering on HP limits but atm it will do with the injectors I have, I'll probably be limited to 450-500whp with what I got.
Old Feb 3, 2025 | 10:46 AM
Jacob VH's Avatar
in case people are interested I did some calculations and here is the limits of the LB7 intercooler. I'll update once I build with my experience.
based on square inch rule (1sq in per 1hp)
looking at about 721hp
Based on 3L per 100hp (2.05" thick)
looking at about 800hp
Old Feb 4, 2025 | 06:58 AM
grubinski's Avatar
Hmmm… bot?
