D1SC what engine should I build?
I have a D1SC Procharger kit with twin 4.5" intercoolers, ARP head bolts and ARP rod bolts, 1-7/8 headers, and a true dual exhaust. I will also be doing a 0411 ECU swap, as well as beefing up the transmission, chassis, suspension, brakes, rear end, fuel system etc to support the additional power. I don't have a budget for this, but I'd like to keep it somewhat wallet friendly.
The goal is a fun street car that I can drag race occasionally. 10s would be great, but 11s are also fine.
Here are the options I'm considering and some thoughts. Please remember these are just bullet points, I know there are a lot of other parts to each of these:
1. Build the LS1 and save the procharger for another project. Replace the perimeter bolt heads with something like TSP LS6 Brawler heads, a cam around 230/232 .600/.600 112lsa, LS6 intake. I think this would be the easiest build, but least powerful.
2. Build the LS1 for the procharger. Aftermarket casting heads (I like Trick Flow, but I cant find them in stock), dumpster fire cam 224/228 .600/.600 114llsa or Tick Blower stage 1 cam 223/235 .615"/.605" 116+5lsa, LS6 intake - I was thinking about keeping it around 7psi to be safe. Is supercharging an early LS1 worth the risk?
3. Buy a 5.3. Open up the ring gap, keep the heads from the 5.3, upgrade valve springs and rockers, dumpster fire cam, LS1, LS2, or LS6 intake. - This should handle more boost, right? If this is a good option, what pulleys / how much boost would you run?
4. Buy a 6.0 LQ4. Open ring gap, keep the heads from the LQ4, upgrade valve springs and rockers, Tick Performance Blower Stage 1 V2 LS2 cam225/237 .62x"/.61x" 116+5lsa, LS2 or LS6 intake. - Same question as option 3: What pulleys / how much boost?
What would you do? Is there a better option I'm missing? I'm not opposed to swapping heads on the 5.3 or LQ4 if it would be a significant improvement. I'm also not married to these cam choices.
I look forward to seeing your feedback. Thanks for reading
Gen 3 5.3 with gen 4 pistons and rods. Rings gapped
862 heads with dual springs
Bald Eagle boost cam
Uograded oil pump, timing chain, balancer.
going to put a d1sc and shoot for 10psi
all mated to a th400 and a 8.8 rear end
Codys89RS: That's another good cam. Did you get the 8.8 from Hawks? Good luck with the build
Its all about the tune.
New owner wrecked it in a month.
Before i roll it back out of the shop I will need to tear it down so hopefully I will have more information!
Sorry to hear about your last car. That would break my heart.
I'm going to keep an eye on your build thread. I'm emotionally invested in that harmonic balancer.
I read 7psi was the safe maximum for LS1s. I don't remember where I saw that, but it stuck with me.
If I swap the engine I'd be more concerned about the twin 4.5" intercoolers becoming inefficient. I remember Bob@BruteSpeed saying they get hot around 14 psi. I suppose I'd shoot for about 12 psi.
I'm leaning towards the LQ4 at the moment.
did you ever decide which route you ended up wanting to go?
Iron block adds 105 lbs to the car. I'm doing the opposite, will pull my SBE LM7 for a fully forged LC9 this year.
Was this something you did often?
Was this a drag car and how high did you spin it?
Sorry to derail the thread lol.
The advice from Pro Stock John and ddnspider convinced me to stick with an aluminum block. I bought an L92 from a 2007 Escalade and I am gathering parts now. I also got a Lunati Black Magic Gen IV supercharger cam (227/244 .614"/.595" 115LSA) before they were gone.
