remote rurbo info needed
im trying to sort out a turbine and the harware id need to make a 600 hp close. turbo. injectors pipe sizing and so.... looking for desecnt reliable stuff.
i already have a fitech 92mm throttle and a holley oil pan... may not change much.
should i run an intercooler? how much boost should i aim for?
ill be running the car as a daily driver and i want it to be the most reliable as possible.
any hints . tips. tech and knowledge is much appreciated .
thanks in advance guys
have a great day
91 octane is the best we have around here. sometimes 94 .
and for piping u mean 2 inch exhaust from headers?
Full exhaust with a cutout would be a better method for maintaining sleeper status.
Stock manifolds, 2" primaries with a nice billet VS 7875 turbo T4 .96 AR would be fun on 91 pump gas and spool very fast.
I ran a cast wheel T7875 on pump 91 on my LS1 and made 700whp thru a T56 at 14lbs.
Stay around 10 lbs. to be really safe and 600whp should easily be attainable.
For fuel you could do dual AEM400's, -08AN feed and return, 1000cc injectors would keep you covered and give room for growth because no one stays at low boost for long lol.
2.5" or 3" piping for the intake, for an IC, CX Racing is decent for the cash, Treadstone is another.
He's gonna need electric pump(s) regardless, OP might want to consider a surge tank, best of both worlds.
I used dual 255's and Deka 80's in my previous car to get me to 700whp on pump fuel, no idea how close to tapped they were as I wasn't logging any of that data via EFI Live.
I'm running dual 450's in my current pump gas car, not because I need them but because they were on sale I wanted all the fuel lol.
The 450's did bring my IDC down about 10% with a -08AN feed from my dual 255's with a -06AN feed.
Using a BSFC of .6 (I think that's correct for gasoline?) and a 70% IDC at redline, I should be just shy of 900chp so if the OP ever wants more power, a 1000cc injector might not be a bad investment.
Not sure on the 55 chevys but they have retrofit tanks for alot of old cars. I've done 1 in a 66 chevelle and currently doing a 69 camaro. I think aeromotive has a kit to use intank pumps in about any tank thats pretty slick.
You're right though external would be the easiest, but if that was my only option I would pony up for a magnafuel 4303. I lost count on the number of 044 style pumps that left me stranded, and by the end they were installed and wired as perfect as they could be imo. I know some guys swear by them though, just sharing my experience
