What size BOV and wastegate
Gen 2's, so still diaphragm but the gen 3 pistons are better. One guy buys the cheap summit 44mm diaphragm waste gates and just replaces them each year.
I’m not a fan of BOV’s. You don’t need to run any. Mainly just for sound. I’ve yet to see any data showing turbo damage from not running one. Or any data that shows improved response with one. Definitely don’t see the need to run 2. I don’t hate the sound, just one more thing to go wrong and added weight/$ for no purpose.
I’ve actually seen data from some road race guys that did laps with and without the BOV and monitored turbo speed. The turbo RPM went up without a BOV between shifts and down with a BOV. Lap times and boost response was actually slower with a BOV FWIW. Opposite of what I though was going on when the turbo “surged/fluttered” between shifts.
I’ve run them on a few of my setups thinking it was the right thing to do in the past. But I keep coming back to the “why bother attitude”. If in the end its just additional time/money for no real purpose.
I believe in the typical street/strip auto drag stuff I build they don’t seem to be necessary. I don’t appear to do damage to any parts without one or suffer any performance loss. Never hurt a TB or turbo (to the extent I could tell anyway.) in the past 20+ years of playing with turbo cars anyway.
Ran 34lbs regularly on my DSM with factory TB. The blade on those are thinner than the LS TB. 30+ on 2jz stuff, 25 or so on GN stuff... etc etc... Hell my 1500cc wave runner sees 16lbs or so at 8600rpm and has no BOV from the factory. And its a centri blower motor! TB on it is tiny thin stuff.
The BOV unbeknownst to me was stuck shut and it took a friend with turbo experience to ride with me to point it out.
After I fixed it, I noticed a definite lull in the power between shifts, it was a T56 car and I assume this is to the boost loss whereas when the BOV was stuck shut it seemed way more responsive on the shift.
I toyed with blocking off the BOV for the entire rest of the time I had the car, it was that noticeable.
I'm running a 105mm Holley TB now only because the car came with it and fortunately, Pat G. has it pretty dialed in.
Every now and then I'll get a dip/bog in the idle when the second cooling fan comes on but that's about all I've noticed.
I don't think my RAF is totally dialed in for the cooler spring/summer mornings but that's my fault.
For the record, I do have a small BOV even though my setup is automatic and a small TB. Just peace of mind.
I don't run a wastegate.... boost is controlled by the TB.
The issue is drivability at low throttle inputs. A mild 5.3 sure doesn't need a 100mm+ TB. I have a 102mm on my 5.3 as it came with the elbow I run. It does have a pretty large "cam" in the throttle cable mount. That opens the blade really slowly at first. So its not horrible to cruise around on IMO. But the factory 78mm def drove better.
