5.3 turbo
If you really know what you are doing tune wise and have a light weight setup with decent gearing you can likely get away with 800ish. I did it for a few passes before mine let go. Couple people pushed gen3 4.8s that far too. But they dont lean on them till well over 5k rpm.
I ran my Gen III SBE LS1 at 700whp for years with a Pat G. tune.
I'd also look for an L33 or LC9 with the Gen IV internals, then you get the durability and light weight of an aluminum block, why add 100 lbs. to the nose if you don't have to.
Gap the rings, add a Melling HV oil pump and let it eat.
Just make sure to check the cam bearings, they can come loose in the block and block the oil passage which is bad.
If you don't plan on making four-digit power, you could always just do rods/pistons in your LS1.
I'm running a rod/piston LS1 right now and plan on taking to 900-1000whp.
Pop the pan off and check.
This is with over 20 psi on 50 percent E and a size 9 meth nozzle full on at 6 psi with 19 degrees peak timing and much lower timing down low.
The Gen IV rods and pistons are very capable and would be just fine for 700whp really.
If it were me, I'd look for an L33 or LC9 w/ 100K miles or more, give it a backyard rebuild.
If you can find an LS3 like @BCNUL8R then definitely go that route, or even an aluminum 6.0L but both those are probably gonna be $$$.
Throw in some fresh bearings and rings since you'll have it apart anyways, check the cam bearings, install a HV oil pump because you can really spin up those 5.3's.
Reuse your heads, head studs, cam, BTR .660 drop in springs and you'll be set.
At least with this foundation you can turn it up when 700whp gets boring because it eventually will and you won't be out a ton of cash.
Have you settled on a turbo?
A 7875 would be easy to package and make the power, a T6 S4xx Borg unit would be ideal but is much more challenging to package in a 4th Gen F-Body.
and for what its worth I have a piston rod ls1 that's properly built and it makes 8-850 with ease going on 3 years now and TONS of passes and nearly daily it in the summer.
as stated above try and get a gen 4 and make sure you got a good guy running the laptop. anything can happen of course but tons of people have had great success.
Doesn't matter how tough the bottom end is if the tune is crap.
Pat G. has tuned all my stuff and I beat on it like it owes me money.
Told Pat "I don't care what it makes, just make it live" and he's done that and made some decent power.
I don't know what my rod/piston LS1 makes now but its taking 14 lbs. from a billet S484 like a champ, gotta be in the 800-900hp range I would think.
With a 377 at 10.6 to 1 on E and meth with 21-22 psi at 19 degrees of timing the horsepower calculators say im around 940.
I figured Id be over 1000 easy but trap speed dont lie like dynos can.
You might only be 750 rwhp if auto with a 347 on pump/meth at 14 psi.
Hoping to hit the track this year for some actual numbers, still haven't heard back from the dyno tuner which bums me out.
Would love to have actual hard numbers to share.
Anyway, OP may want to consider doing a rod/piston combo using his current LS1.
Im trapping just over 115 at over 4000 lbs. I want to get in the 8s in the 1/4 driving to and from the track. Ive been 6.1 and figure I need to go 5.8 at 118 to hit 8s in the 1/4 as a guesstimate. Dont want to make the long drive to the 1/4 track until I run an 1/8th time that gives me a real shot at it. The 1/8th mile is 10 minutes from home.
Ive got funds set aside but cant decide between using a sleeved lc9 or lsx block or a 388 or 427.
I just went 6.1 at 115 and added 2 more psi since then.
I found out the coyote guys are spinning Prochargers 15-20,000 rpm over max recommended impeller speed so I figure spinning it 10g over cant hurt lol. Its not that they become inefficient its the reliability of the gear set at those Rpms but its only for a second that its over the recommended range lol.
