Stinky Turbo Blanket
Old Jun 24, 2025 | 01:20 PM
Full Power's Avatar
Default Stinky Turbo Blanket
Does your Turbo Blanket smell like a burning carpet ?
Pretty sure I don;t have an exhaust leak Maybe have 50 hours of run time with blanket on, still smells like a wet dog sleeping too close to campfire..
Getting ready to just run NAKED.
( How many run naked on the street? )
.edit: How do you make a POLL ?
Old Jun 24, 2025 | 02:10 PM
Forcefed86's Avatar
Spray it down with BBQ grill paint to seal in the stank. Though I can honestly say I never had a super stinky turbo blanket.
Old Jun 24, 2025 | 03:42 PM
Full Power's Avatar
Maybe it WAS an exhaust flange leak: Had a copper gasket in there, between downpipe and Marmon outlet flange.
Most guys run the downpipe straight Steel to STEEL, right ?
Old Jun 25, 2025 | 11:12 AM
Forcefed86's Avatar
All kinds of theories there. But yea if its flat I don’t run a gasket. Burnt RTV def. stanks.
Old Jun 30, 2025 | 03:47 AM
91 Z28's Avatar
Get yourself a better quality turbo blanket. I run a black sheep industries blanket and it's mint ?
Old Jun 30, 2025 | 01:33 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I had blankets on mine to protect other components from heat, rather than to keep heat in the turbo for spoolup. After an issue with a bad oil supply line, then another leaky oil fitting, I decided to ditch the absorbent fire hazards completely. I use the dimpled aluminum heat shield stuff like the OEMs use on exhaust now. It was easy to cut pieces from a sheet and form to fit, then rivet in place. The bonus is no more itching every time I open the hood.
Old Jul 1, 2025 | 07:03 AM
LQ4-E39's Avatar
No blanket ever here on 3 builds, no problems.
Old Jul 1, 2025 | 08:39 AM
sysyclone's Avatar
Put a Piece of Heat-Shield between the Turbine and Blanket. Have had ebay/amazon Blankets want to burn (also stink) and this stops it.
Can buy new, or get pieces from the underside of vehicles.
Old Jul 1, 2025 | 09:28 AM
Forcefed86's Avatar
I will say if you drench the things in BBQ grill paint they no longer drop glass particles everywhere and they shed water/oil (to a point anyway). I don’t have any of the usual glass mess once coated. I believe the lava mat blankets also dont’ shed any glass, but they are more expensive. I juse the dirt cheap blankets and heat wrap. Then hose them down good w paint to lock all that crap in.
That stainless shield is also weldable. Can s secure it with a bunch of little tig spot welds and it looks great.
Old Jul 2, 2025 | 06:56 AM
LQ4-E39's Avatar
That stamped heat shield material looks like it would serve equally well to hide my awful looking welds on the downpipe.
