Breaking up/misfiring under boost
I'd do plugs, check the turbo system for a crack, then check intake.
When I got my car the passenger side v-band was loose at the header and the flanges were offset causing a large exhaust leak, car still made boost and ran normally.
I'd start with what's been suggested, plugs and wires.
Check your grounds, make sure you aren't dropping voltage at high rpm, confirm your AFR, wiggle check the injector plugs and maybe just give everything a good look over where you were working, you might have moved or knocked something loose and not known it.
Should have asked but when you swapped coils did you swap as an assembly with a different harness by chance? IF original harness wasn't swapped look at the harness wires closely just for ***** an giggles.
When you start getting frustrated you can easily oversee something. Take a five. If plugs don't do it stop take a 5 you will start chasing you tail and will miss the simple thing staring right at you. That's an easy way to marry a car especially on flat rate...
This is where a stock ecu comes in handy with a misfire counter etc. or it can ruin your day just the same.
As a side note, why in the hell are BR7EF plugs so damn expensive everywhere but Summit Racing? Every chain auto parts store wanted $6-7.50 each for these plugs, but Summit had them for $3 each so I ordered 16 just so I'd have extras on hand.
I think with as high powered as our ignitions are and as much as we're asking of them, wires should probably get replaced along with plugs more often.
They've been on the car since the turbo went on but they don't have a ton of miles on them.
Fingers crossed for a good lick and a 10 second slip!
Glad the plug wires worked, maybe one of them is bad, I think if you had the wires on fairly good it would not misfire.
