Breaking up/misfiring under boost
- Swapped all coil packs out for different ones ( D510C coils )
- Pulled plugs to inspect ( BR7ES plugs ), all look good. .020" gap
- Resistance checked the plug wires, all are roughly 150 ohms
- Swapped out the crankshaft position sensor with another GM one
- Replaced the fuel filter
- Compression test, all within 3-4%
I've datalogged numerous times and the Holley software isn't showing any issues with crank signal, but AFR is jumping around a bunch. I have a table in the tune adding .2 milliseconds dwell above 7.5 lbs. of boost, but that didn't cause any problems previously. The only thing that is still the same are the plugs and wires. The wires are Summit house brand, but they've never given me any trouble. The plugs look almost as clean as the day I installed them, just a slight tint to the porcelain. I'm probably going to swap plugs and wires because it's the only thing I haven't swapped out yet. Anyone else have experience with this?
As for AFR, it's fluctuating a bit, not seeing spikes in either direction though. I checked the grounds on the coil packs, they're nice and snug. Doesn't misfire out of boost under a load, it's only when the turbo spools up. All the plugs look great. One could be cracked, though. Since they're cheap, I'm going to replace them for piece of mind.
So something is taxing it under "extreme" load. I hate throwing parts at a car but in this situation plugs might be in order and for piece of mind. Cheap easy. One fouled plug one big headache.
This is all an assumption its an ignition misfire and not fuel. Since your in there anyway put your hands of on the injector plugs make sure nothing is loose.
Hopefully reluctor didn't move on the crank.
