Leaky Procharger Bypass valve??
Old Oct 26, 2025 | 12:06 PM
30th t/a's Avatar
Default Leaky Procharger Bypass valve??
Guys, when I put 10 psi of compressed air to this bypass valve, it is leaking out. I'm assuming this is not right. I did have the vacuum port connected to the vacuum line when i did the test. Can anyone confirm this? Thanks
Old Oct 26, 2025 | 01:51 PM
NoGo's Avatar
I think its a pressure assist on the close. You have to have boost/vacuum on the sensing line. Vacuum opens it, but the boost helps keep it closed under boost.
For the record, I have had a multitude of these things and the only time I ever had a leak, the diaphragm had worn out.
https://ls1tech.com/forums/forced-in...diaphragm.html
