Not ls related please read description
specs for the turbos \/
COLD SIDE
gt35 61/82 billet comp wheels
gt35 .70 a/r 4” inlet 2.5” outlet
HOTSIDE… now this is where I’m stuck in choosing what turbine wheels I should keep as a set & forget for a broad hp range from low (stock motor) 400whp to high (built motor) 700whp
Standard turbine wheels
Turbine Inducer: 64.8mm
Turbine Exducer: 55.8mm
or
stage 3 turbine wheels
Inducer diameter: 65.0mm
Exducer diameter: 56.59mm
Turbine housings .63 or .82? what ever I end keeping will be t3 3” vband outlet turbine housings
motor will have stock cam with 1.98 rockers (custom) with 130# valve spring, stock heads or mildly ported heads (budget dependent) and stock or mildly ported intake manifold (budget dependent) with 3” y pipe to ether 3” or 3 1/2” single exhaust to the back bumper
what do you guys think?
