Hot vapor engine...
Old Jan 12, 2026 | 08:59 PM
wannafbody's Avatar
Default Hot vapor engine...
Why don't we remove the intercooler and add a fuel injector in front of the supercharger or turbo?
Old Jan 13, 2026 | 05:45 AM
BCNUL8R's Avatar
Who is we?
You can do what ever you want and that’s literally been done before with 100 percent methanol.
Old Jan 13, 2026 | 06:48 PM
wannafbody's Avatar
I meant enthusiasts in general. I thought methanol acted as a coolant in the intake track dropping temps.
Old Jan 13, 2026 | 07:27 PM
DualQuadDave's Avatar
Paging Smokey Yunick....
Old Jan 13, 2026 | 07:49 PM
NoGo's Avatar
I have a pre-supercharger methanol injection CIP on a switch that I turn on on hot days. It doesn’t do much for power (have the Dyno comparison around here somewhere). It does notably cool the charge, but it also displaces air/O2 which counteracts the cooling effect. Its more for just cleaning the inlet of the S/C at this point.
Old Jan 14, 2026 | 12:02 PM
BCNUL8R's Avatar
Thousands of people have used meth injection for this reason or for additional octane.
People have also used an actual injector or two in the intake without an intercooler. It was even talked about on a street outlaws episode because they were doing it. An actual injector is going to need an aftermarket ecu or controller of some sort where a typical meth nozzle does not.
Old Jan 19, 2026 | 10:47 AM
Old Buzzard's Avatar
We used this 35 yrs ago. Worked well enough prior to bigger injs and driver mods in the ECU.
(158) ATR Seventh Injector System | Turbo Buick Forum | Buick Grand National | T-Type | Turbo T
