Oddball cam/turbo recommendations
I'd spend a little coin on the IC as well, Treadstone, Garrett, Bell are all great and more importantly efficient.
I run an A2W in my streetcar and there is nothing better, a reservoir would fit in the bed quite nicely.
The water just sitting in the A2W cooler is an incredibly efficient heat sink that I only turn the pump on from time to time.
Even ambient temp water works incredibly well, I haven't tried ice yet but I'm sure it will only help make more power.
If I know I'm going to be beating on it then I'll kick it on but even if its not running and I make a quick pull, my IAT's still stay very low, maybe 10-20 degrees above ambient tops.
I run a Frozen Boost Type 22 cooler, 3/4" lines, 2-3 gal reservoir and a Rule 2000 pump.
My cooler is located in the nose of the car so it's away from engine heat which I'm sure helps so you may want to consider having both the reservoir and cooler in the bed of the truck.
Water to Air Intercoolers
I'm leaning towards a VS7875 divided 1.25ar with that summit manifold. Research says that will spool better than a 7875 open with .96ar and have less back pressure too. By the way I called BTR and they recommended their Stg2 turbo cam (220/223 .618/.618 113Lsa) over the truck norris for my scenario, so I ordered that.
Following your lead on the firing order, I did a bit more research into whether or not a divided housing is even worth it on an LS engine due to the firing order not being a perfect split between alternating left and right banks. Here's the answer I got: "The divided housing still reduces pulse interference enough to make a massive difference over an open housing"
Thanks for all the suggestions.
range as that’s where I spend 90% of the time. I don’t get to rev out to 6500 much as it means I’m being dumb and going to fast on public roads lol. I daily all my cars to work 40 miles in stop and go low speed traffic in blistering summer heat so I plan accordingly. If I need to rev out I can, is the turbo optimal for that no… but it is for 90% of my driving.
Ultimately I bought the nextgen 7875 with a 1.25ar divided housing. With a small 2" hotside and the divided housing, it should still spool fast enough and have a bit less backpressure. I'll report back once I get it all together and start driving it.
Just be careful about making too much boost down low, nobody wants bent rods lol.
